60mm - 63mm T.B
Blk-Jet
60mm - 63mm T.B
Post by Blk-Jet »
Hey all again,
If you want your Throttle bodies bored out to 63mm then please contact me, if i can get enough numbers i'll run a line and maximum dollar figure will be $50 per T.B not including delivery.
Cheers
GPXXX
Post by GPXXX »
just out of interest, what sort of HP difference will an extra 3mm clearance give?
Blk-Jet
Post by Blk-Jet »
-- Standard 60mm gives = 2827mm^2 of surface area.
-- Bored out to 63mm gives = 3118.2mm^2 of surface area.
It doesn't look like much but the gains are there. Without an adjustable computer your gains will be approx 4-6hp. with computer approx 6-8hp.
FTO338
Post by FTO338 »
so how many ppl u need then???
d_stroy_r
Post by d_stroy_r »
The main problem is............you live in Melbourne :cry:
Blk-Jet
Post by Blk-Jet »
the number wont matter anymore, i just want to see some more fto's out there with engine mods done rather than stickers, no offence to anyone, i'm getting some made up as we speak :)
If anyone wants em done just email me at frank_mileto@yahoo.com and we can organise a day etc.
FTO338
Post by FTO338 »
Hey is that your real email address or u did a mistake here?
cause heres the msg i get when i try 2 send u a email!!!!
"Remote host said: 554 delivery error: dd This user doesn't have a yahoo.com account (frank_mileto@yahoo.com) [-5] - mta120.mail.scd.yahoo.com"
GPXXX
Post by GPXXX »
Blk-Jet
Post by Blk-Jet »
sorry guys forgot to put the .au at the end
try frank_mileto@yahoo.com.au
kaveman
Post by kaveman »
hi blk-jet
with these bore out are you replacing the butterfly
and do you need to mill the intake also
thanks
robert
Blk-Jet
Post by Blk-Jet »
yes, a new brass butterfly will be fitted to the original shaft, and the diameter of the shaft itself will be sanded down.
Everything else is original w.r.t. the T.B.
As for the intake plenum, this too will need minor grinding to increase it to 63mm.
hnm738
Post by hnm738 »
when u say 4-6 hp gains
it that at the wheels or fly wheel?
and so how much would it be all up?
Blk-Jet
Post by Blk-Jet »
The 63mm boring of Throttle bodies is now good to go.
Anyone wanting this done can choose from the list of prices etc.
1. Original Throttle Body bored to 63mm, grin.ded shaft, new brass buterfly, sand blasted, flow tested, gasket.. Approx gain 6-10HP at fly (standard)
Price: $150
2. As per #1 and also including the intake manifold being bored to 63mm to match port the TB. Approx HP gain: 10-12HP at fly (standard)
Price: $200
Blk-Jet
Post by Blk-Jet »
Price: $150
Price: $200
Please contact me at: frank_mileto@yahoo.com.au.
Preferable in Melbourne but will take interstate provided they pay for postage costs.
FTO338
Post by FTO338 »
hey got a loaner, while our car is off the street cause of this mod?? hehehee
email on your way buddy!
everyone do a dyno run before the mod and see the results.
Blk-Jet
Post by Blk-Jet »
Good idea! That's something I should have done before I started doing all my mods!
Black_FTOGPX
Post by Black_FTOGPX »
Would you need some sort of aftermarket computer to prevent Flat Spots?
Sorry it’s just that I don’t know much about this kinda thing.
Where about in Melbourne are you?
Cheers
Blk-Jet
Post by Blk-Jet »
You don't need a computer for this mod. The ecu can update the fuel supply for the increase in air.
having a computer siply means you can increase the fuel in more depth and get that extra poofteenth of a kw out.
I'm in Bulleen, about 5 mins from shoppingtown doncaster. I've had mine done already so you can come down and have a look at the quality etc.
I'm also performing this on a 200s and r34 gts-t, so i'll post up the results of all of em so you guys know what your buying!
If only my digicam was working :(
G_A_V
Post by G_A_V »
howl ong would it take if i sent mine down from sydney, got it doen and sent back up ??? I can get before and after dyno charts too
