Cooling a Turbocharged Engine
- FtoSam
Okay, after watching my temp guage it is now much more prone to creeping up a bit on hot days... so i need to cool it a bit.
Was thinking aluminium radiator. I know Danny has one and i thought that would be sufficient.
I was also wondering if an oil cooler would be usefull??
Being manual i dont need a transmission cooler.
The idea is to give this engine everything it needs to last.
I plan on forged pistons(which also lower compression to 8:1) soonish and upping the boost to around 14psi. So i plan to upgrade things to be able to handle what lies in store for my baby.
BTW: what does anyone think i could pull (HP and qtr mile times) at 14 psi? Keep in mind i plan to pull out stereo for track stuff.. as well as CF bonnet, lightweight rims and CF boot. (dunno if it makes heaps of difference.)
- FTO338
Low 14 or high 13 if you get it right.
Vented bonnet, but its illegal though.... or front nos cooling kit like in the 2Fast2furious R34 GTR.
- khunjeng
- FtoSam
- FtoSam
- FTO338
This reminds me of some of the dyno run Vic members had, some of us pull around 500nm of torque
Dyno sheet proven.
Paper figure don't mean sh*t, OTR performance is what makes the different between tosser and winner![Very Happy :D](./images/smilies/icon_biggrin.gif)
- khunjeng
- FTO338
I'm talking about the FTO dyno sheet, not Sky, my ex-FTO was like 480Nm
Wait till my warranty is over for my rides, i give you some run for the money.....but like you said before, i probably change car by then....![laughing :lol:](./images/smilies/icon_lol.gif)
- khunjeng
- Vaeth
Re: Cooling a Turbocharged Engine
Samson wrote:Okay, after watching my temp guage it is now much more prone to creeping up a bit on hot days... so i need to cool it a bit.
Couple of other things that could help with cooling:
* Lower temperature thermostat (radiator cap)
* Better fans for the radiator/oil cooler/intercooler. (i.e. SPAL fans)
--V
Definitely an oil cooler and you can invest in a fan controller where you set the temp for the fans to come on etc. Water injection kit will also help as will heat wrapping anything close to a heat source. Make sure your coolant system is working effectively also. If you havent already may be a good idea to flush the system and ad new coolant. Redline Water Wetter is a nice additive also. Do all of that and you should have 0 heat issues.
- khunjeng
Redline water wetter is def. good. I use it and drops the temps easily by a few degrees.RedlineGX wrote:Definitely an oil cooler and you can invest in a fan controller where you set the temp for the fans to come on etc. Water injection kit will also help as will heat wrapping anything close to a heat source. Make sure your coolant system is working effectively also. If you havent already may be a good idea to flush the system and ad new coolant. Redline Water Wetter is a nice additive also. Do all of that and you should have 0 heat issues.
I would take apart my whole cooling system, flush and replace as necessary. Maybe a better radiator would be good also. But dont go crazy and buy an ARC one for 3k.
- FtoSam
- FtoSam
- dannyboyau
- FTO_ADZ
I find if you go really really fast and then just glide at high speed helps squeezie.... hehehe
Well cause the heat of the turbo 700degs+ it doesnt really help, so when you get home, pop ya bonnet for a hour or so, will help from frying something out!!
Race yourself, it's better than being beaten by an FTO :-)
- FtoSam
