right wheel bearing..HELP>..
tj2709
Post by tj2709 »
rear left wheel bearing crack...where can i get another one? please..help urgent.. :cry:
best idea would be your favourite wreckers or ask dwayne really nicely OR email www.kempys.co.nz
oh and dont drive on it! even though its just a trailer wheel it could still cause some major damage if it goes pop at 50k
Might
May be able to help.... PM sent
    Bearing are generic. I would advise against using a second hand one.
    Try places like CBC Bearings in Artarmon (they are in the whitepages) and take your old bearing down so it can be matched with a new one.
    There you go
    If they are generic, this would probably be a much better option for you (and me atm time is a bit tight coming up to Chrissy) - thanks Bennoz :D
      Hehe, its certainly another barked knuckled saved for you.
      hmmmm
      hmmmm... yes.... lets not go there shall we......
        tj2709
        Post by tj2709 »
        yeah..i'm lookin for a brand new..not the second hand...i will try to find the new one first..if i cant find it then i will contact one of u guys...thanks a lot for the help guys...
        RallyMad
        Post by RallyMad »
        sorry for dragging up an old thread but I've also been told the rears can't be pressed out.
        The workshop that has been looking at this for me swears you can't press it out cause you can't even get to the bearing as the hub is built around it?
        Am I correct in thinking with my car having ABS I should use the MR316500 or MR131217
        Really don't want to fork out $500 for a new bearing so Please HELP :? :(
        I think I got rid of my last decent 2nd hand one this week, but I guess I can have another look. I know this is little solice, but I could get a new one for less than that (not heaps though now the dollar has dropped so far)
          RallyMad
          Post by RallyMad »
          Thanks dstocks, it's not real noisy yet so I can probably hold out for a while if I can't find anything but a mitsubishi one. I'd prefer a new one anyway thanks mate so I've save your knuckled on this one but thanks ;)
          I'll send you a PM tomorrow or Friday if I need one from Japan.
          More after someone to confirm for me that the bearings can be removed and re-pressed? As in has anyone actaully done this? If so has your car got ABS, I'm sure this shouldn't effect it but I'm thinking that could be the source of the problem.
          Seeing a mechanic tomorrow about another noise anyway so hopefully he might be able to sort this for me as well if the bearing can be changed and not the whole hub.
          jonowong
          Post by jonowong »
          i've got a brand new genuine hub and bearing that ill let go for $150
          Id take that if I were you rallymad. You wont get a better deal
            RallyMad
            Post by RallyMad »
            PM Sent Jonowong.
            Could someone with CAPS please tell me what is the correct part number for my car please. Chassis # is DE3A0201521.
            I had one today for a little over that price but it was the wrong one, something about the 5 holes (not the stud holes the other ones) not being countersunk for the ABS. The guy lost me there cause I thought the ABS sensor stuck out the middle of the hub assembly but anyway. :?
            Tip for anyone if we can sort this, Bursons has a supplier than can supply FTO rear wheel hubs for under $200, just it was the wrong one for mine and the supplier reckons there was only ever one for FTO's. hmm sure, thanks to dstocks I know at least that isn't true. Thanks Mate ;)
            The right one for yours is MR316500 mate. Looking at caps, the difference seems to have nothing to do with ABS, and more to do with Pre/Post facelift models. Yours must be 97 or later as it uses the later model hub. Cant tell you what the difference is. They may even be interchangeable.
            Oh and tell the Bursons guy hes dreamin......
              RallyMad
              Post by RallyMad »
              thanks dstocks, just confirming through the workshop if there is much difference between the 2. Come to think of it I think the one from Bursons I had yesterday was even different to the one Jonowong has.
              PM sent Jonowong & dstocks
              RallyMad
              Post by RallyMad »
              Is anyone able to find me a photo of what the MR316500 assembly looks like please...
              Very concerned now, getting close to needing $460 and 3 weeks wait for one from Japan through mitsi aus if dstocks can't help me :cry:
              Another word of warning...the bursons one is nothing like the MR131217 one that Jonowong fitted to his car in his DIY, seems it won't even fit any FTO.
              RallyMad
              Post by RallyMad »
              actually camskill has them.
              http://www.camskill.co.uk/products.php? ... _Driveline
              For everyone, see the 4 countersunk holes on this one, seems like a ABS or at least face lift thing. This means the MR131217 and MR316500 are not interchangable.
