Anyone help ?
Cheers
Was pretty easy to do. Would be a good job for getting used to this sorta thing. Bit of rolling around under the car. Dirty Hands. There's not that much you can really do wrong... Just don't scratch the paintwork.gazeek wrote:... is taking my front bar off much of a task ? ... I rarely take outer parts of my cars apart .. or should i just buy it and keep it for next time i take it in for a service .. get them to do it ..
You could always be a slack-ass like me... I just kept the mesh in one piece to cover the top and bottom holes. I bent the bottom of the mesh in along the bottom vents by about 45 degrees (just make sure the mesh is held flat over the holes while you bend it). There is a plastic shroud that sits between the front bar and the radiator which sandwiches it in there. There is a little bit of movement on the outside vents, but I did mine 4 months ago and it's been fine.gazeek wrote:That guide looks good , all the way up until it mentioned drilling new holes in my front guard .. which i think id be worried about ..
