BJK's '95 GPX
Re: BJK's '95 GPX
So, one thing follows another, and the alternator is one the way out as well. :lol: Found this on ebay, not sure if it's the right one?
http://www.ebay.co.uk/itm/NEW-MITSUBISH ... 6#shpCntId
Re: BJK's '95 GPX
Says 4 pin, so should be OK.
    Re: BJK's '95 GPX
    dstocks wrote:Says 4 pin, so should be OK.
    Yeah, and the part number they have listed is MD317515. I saw in one thread that there is apparently a newer version of it, but it's been doing with the older one anyway and this is a lot cheaper than most others.
    Dammit, neglected to note that free postage was only for the UK, haha. Still might end up being worth a shot though.
    Re: BJK's '95 GPX
    Have had a few occasions of hitting bumps and the handbrake light coming on and not going off for a bit. Thoughts?
    Re: BJK's '95 GPX
    bjk wrote:Have had a few occasions of hitting bumps and the handbrake light coming on and not going off for a bit. Thoughts?
    I drove a 2011 Triton a few weeks ago that did the same thing. :lol:
    Re: BJK's '95 GPX
    Yeah, I suppose "Thoughts?" was a little too opened ended. :lol:
    Re: BJK's '95 GPX
    Brake fluid low!
    Re: BJK's '95 GPX
    Sahin wrote:Brake fluid low!
    Huh. I couldn't get the lid off (is it pressurised or am I just weak?). And I can't tell if the dark bit near the full line is just part of the cap or not. But it doesn't look like any liquid is in there. :?
    Re: BJK's '95 GPX
    You're weak and yep it's gonna be that I'm sure of it
    Re: BJK's '95 GPX
    Cool beans. Maybe I'll dash down to Repco and grab me some fluid and a tool kit, lol. I just get the lid off and fill it up, yes?
    Re: BJK's '95 GPX
    Just use an oil filter wrench or get ruby to take it off for ya hahahaha
    Re: BJK's '95 GPX
    Sahin wrote:Just use an oil filter wrench or get ruby to take it off for ya hahahaha
    I have neither of those things! :(
    Tiiiiiim, get back from Japaaaaaan! :lol:
    Re: BJK's '95 GPX
    Try again wuss
    Re: BJK's '95 GPX
    Sahin wrote:Try again wuss
    Repco was closed. :( wasn't even 5pm lol. Might have to do it tomorrow.
    Re: BJK's '95 GPX
    Yip brake fluid and toughen up easy to remove. Shouldn't be low though unless have slight leak. Check all bled nipples on calipers too
    Re: BJK's '95 GPX
    And master cylinder! Check for leaks
    Re: BJK's '95 GPX
    :facepalm2:
    Re: BJK's '95 GPX
    vipfto wrote:Yip brake fluid and toughen up easy to remove. Shouldn't be low though unless have slight leak. Check all bled nipples on calipers too
    Yea about to say, must have a leak because I haven't had to fill mine up since we all did our rotors at the same time?? :roll:
    Re: BJK's '95 GPX
    Hmm. Most curious. Kiz and Phil can look for me this afternoon? :lol:
    Re: BJK's '95 GPX
    bjk wrote:Hmm. Most curious. Kiz and Phil can look for me this afternoon? :lol:
    Just seen this post and I guess we didn't look at it for ya :lol:
