Bennoz 6A13 Conversion
evoman
Re: Bennoz 6A13 Conversion
Post by evoman »
Woow. As usual you leave me wishing I knew half the sh*t you know about cars.
The damaged teeth on the secondary shaft, looks a bit nasty though. Hope you're right and that they don't shatter anyway.
DaveO
Post by DaveO »
What about the bearing to housing fit?
If that bearing has spun won't the housing be buggered?
:cry:
spency
Post by spency »
I may or may not have a box of gearbox sh*t for you to play with. Includes the LSD out of my old box. Car is
Coming off the road till I can either afford to do a major service or learn to do one over night.
DaveO wrote:What about the bearing to housing fit?
:cry:
You'd think so hey, but it wasn't too bad. Couple of scores I just linished up. Leads me to think the retainer plate they've used when they built this box came from my old box (which was destroyed cause the tards that put it in neglected to put any oil in before dynoing the car.) I'll check out the housing on the old box tomorrow if I get a chance. To try & stop it happening again, I threw a 5 thou shim under the bearing so it's clamped pretty hard against this new plate.
Something tells me this will happen again thou, putting 250kws into a box designed to take 150 is always gonna be trouble. Got an engineer mate who's gonna duplicate the retainer plate in K245 tool steel for next time.
evoman wrote:The damaged teeth on the secondary shaft, looks a bit nasty though. Hope you're right and that they don't shatter anyway.
Yeah thats the whole point of smoothing off the rough edges, to 'destress' the faces. They should be ok for a while anyway. As mentioned above with the power thats going through this box, Im giving it a 12-24 month lifespan lol. Don't reckon she'll go much more than that, its just one of those things with modified cars! I really should get hold of a Legnum box..
spency wrote:I may or may not have a box of gearbox sh*t for you to play with. Includes the LSD out of my old box.
I'll certainly take it if you're binning it.
rock_it wrote:And I was gonna get mother inlaw to make ya Nasi Goreng..
Gah! :o
*Books Craig in*
Lol and Gadu Gadu..
Box is back together, all shimmed & torqued up :)
Will try wack her in tomorrow & be done with it! Just gotta pickup the intake pipe (with new bov outlet welded on) and when the box goes back in, Im gonna chuck another starter motor in from my spares. One that was in it was starting to get a little weak. Not surprisingly.
Then thats it!! No more work required in the short term :cheers:
Oh, apart from the seat rails :lol:
Then Im going out to the Creek to see what she'll do down the quarter, then back to Wakfield :)
Modified pipework for blow off valve :D
Mmmmmmmm so shiiiiiiinnnnnnnnnnyyyyyyy :D
I polished it on the grinder just for you :D
AJ
Post by AJ »
Bennoz wrote:Then Im going out to the Creek to see what she'll do down the quarter, then back to Wakfield :)
After the Bonfire though please, don't want it in pieces before then.
2nd that ^^^^^^^.
I will have to try to get some time off work and go for a run as well :twisted:
Ye of little faith...
This ^
If i can do a full gearbox in & out rebuild in less than 10 hours, I can do anything :cheers:
She's all back together now, went for a neck snapping, tyre shredding session yesterday arvo :twisted:
love the pic :lol:
BOV, Pipe and alcohol sweet mix :twisted: .
:D And the piece of pipe I used was a genuine Nissan water pipe! :o
So you can put a nismo sticker on the back of the car now :lol:
AJ
Post by AJ »
On the road :cheers:
Looks sweet :D
But now you need a nice set of side skirts and back bar :twisted: .
aza013 wrote:set of side skirts
just the skirts would do in my opinion.
But thats me.
