The Suspension Thread
jonowong
Post by jonowong »
i broke the old mans axel grinder like 5 years ago hahaha i have a hack saw but 8)
jonowong
Post by jonowong »
one more thing...
pardon my ignorance but whats this? my drivers side one seems to be damaged...
this is the drivers side...
passenger side looks abit better and straighter
whats damaged? and can i replace it myself? looks pretty easy looks like two bolts and im done...
Thats your lower control arm rear bushes. Yep they are 2 bolts to get out - not too hard. Having said that - there is no point doing them without doing the front bushes on those control arms as well. Putting a new bush into a system that uses 2 bushes will result in the new bush wearing at twice its normal rate. The front control arm bushes are pretty easy to change too. Just the 1 big bolt that goes through them.
Here is the arm dropped out from under the car
jonowong
Post by jonowong »
thanks for the help...
im still confused though...
because i dont see how that part could be this
http://www.camskill.co.uk/products.php? ... b0s10p1348
Thats because its not - that bush is for the GPvR only :wink:
jonowong
Post by jonowong »
ooooo f**k do i feel stupid...i dont think they have the pic for the gpx :P
lol and whatever you do dont buy them from Camskill.... see the "Made in Australia" on all their bush packs?
*taps nose*
All made here
jonowong
Post by jonowong »
:lol: u make me feel more stupid with each post!!!
im still scared to order the wrong part haha
is it this?
http://www.camskill.co.uk/products.php?plid=m3b0s10p363
it doesnt look like it will fit where do the 2 bolts go?
jonowong
Post by jonowong »
hey i just realised we're talking about 2 different things...
i was talking about the piece of metal holding the rear bushes in... mine seems abit stuffed... like warped...
jonowong wrote::lol: u make me feel more stupid with each post!!!
is it this?
Yep thats it. that braket with the 2 bolts wraps around the bush 7 holds it up against the underside of the car.
Part numbers:
SPF1160 for the front 2 little bushes & steel crush tube
SPF1500 for the big one at the rear
Buy from Superflex or Fulcrum Suspension :wink:
jonowong
Post by jonowong »
whats the part number for the bracket? i wanna replace that too :P
MB808264 :wink:
Probably better off getting it from Panelhouse that Mitsi :)
Lemo
Post by Lemo »
Hey Bennoz,
What hight is your car off the ground at its lowest point?
Lemo wrote:Hey Bennoz,
Unsure... i'll check it out for you. Its not mega low being a daily driver & all :wink:
jonowong
Post by jonowong »
had a closer look at my suspention just then...
and ive found more problems...
droplinks look pretty stuffed
and what the hell is this? it looks stuffed aswell? can someone tell me the part number?
Lenny
Post by Lenny »
Hi
Just want to confirm to tighten things up i would order these???
SPF1160 Front Control Arm - Inner Front Bushing x 2
SPF1500 Front Control Arm Lower - Rear Bushing x 2
SPF1344 Front Sway Bar Mount To Chassis Bushing (16k) x 2
SPF2092B Rear Sway Bar Link Bushing Kit x 2
SPF2004 Rear Sway Bar Mount To Chassis Bushing (18k) x 2
SPF1574 Rear Trailing Arm - Front Bushing x 2
If so, who do i get these through..?
I just want to be able to give it to my mechanic and request these all put in...My mechanic says that all the rubbers in my car are in ok order but i would like to replace anyway....
Thanks guys
jonowong
Post by jonowong »
all from superflex... SPF stands for superflex i think...
can someone help me with my probs please?
jonowong wrote:all from superflex... SPF stands for superflex i think...
Jono, they are your droplinks. They tend to be the first thing to wear on FTO's but just cause they look sh*tty doesnt mean they are... they are the exposed to the elements under the car..
To check them, grab a hold of the bar & twist it, see how much movement you get. As they are mounted to the swaybars by ball joints you should get some movement in them. If they are really loose, the ball joints are worn. If they are really tight, the ball joints may have seized. When they lock up, you tend to hear a crunching noise when you go over bumps.
Cheapest place to buy them is Camskill... they use'd to have a package deal for all 4 but I dunno if its still on.
The other item you've taken a pic of is the steering arm ball joint. If the rubber is f*ckled on that then dirt & grit may have got into it. Again it is a ball joint connection. You'd probably have to get that from Mitsi.
Lenny wrote:SPF1160 Front Control Arm - Inner Front Bushing x 2
Lenny, do you have a GR or GPX? All the bushes you list are fine, except SPF2004. That bush is for a GR - it is the GR equvalent of a GPX droplink.
If you have a GPX then you dont get that, instead you get proper droplinks.
Lastly, SPF1574 for the rear trailing arm - factory bushes on those arms dont tend to wear too badly. I'd get your mech to check out the ones you have, because they are mega expensive replacements as far as bush prices go. They are a friggen big bush.
Now I cant remember if Superpro sell direct to the public, if they do, thats who I'd be calling to get those bits. If not, try Fulcrum suspension or Pedders :wink:
Lenny
Post by Lenny »
Thanks Bennoz,
Yes my car is a GPX,
I will try my mechanic for these to see if he can organise them for me otherwise i will get in touch with Falcrum
Cheers
