That's because none of ours were difficult to remove :pc3rbera wrote:It was midnight...I got bored lol...
https://www.youtube.com/watch?v=OKlBnhcLKRo
All so simple, Technikhaus should've mentioned how hard it would be to get the lower casing bolts out ahaha.
(Rad video btw)
c3rbera's GPX
Re: c3rbera's GPX
- c3rbera
Re: c3rbera's GPX
Yeah I didn't think so, more protein shakes for me
Manual '95 GPXsilverGPX wrote:Nice supra
- vipfto
Re: c3rbera's GPX
Now just need to remove factory air feed and replace with ram and maybe use factory box with new less restrictive pipe to throttle body
- kiz
- SA Coordinator
Re: c3rbera's GPX
EFAvipfto wrote:Now just need to remove factory air feed and replace with a turbo and maybe this will be less restrictive to throttle body
1998 Mitsubishi FTO GPVR AERO
- vipfto
Re: c3rbera's GPX
Well I know I will be doing this for you one day......
- Shhtuart
Re: c3rbera's GPX
Did I send you 3 of the ring clamps?
BTW, the yellow looks good
- kiz
- SA Coordinator
Re: c3rbera's GPX
How do you feel about attempting a supercharger project?vipfto wrote:Well I know I will be doing this for you one day......
- vipfto
- vipfto
- kiz
- SA Coordinator
Re: c3rbera's GPX
Hahaha, I can see that ending badlyvipfto wrote:Hell should eeven sc mine then never be off boost
- vipfto
Re: c3rbera's GPX
Not if done right..... but love a new challenge sc wouldn't need intercooler either making plenum and sorting pulley would be main issue
- kiz
- SA Coordinator
Re: c3rbera's GPX
question is; who's paying for the custom jobvipfto wrote:Not if done right..... but love a new challenge sc wouldn't need intercooler either making plenum and sorting pulley would be main issue
- vipfto
Re: c3rbera's GPX
Well if you want it done guess you. I could probably fab most stuff up but a lot of trial and error fueling and ecu easy enough to do though
- kiz
- SA Coordinator
Re: c3rbera's GPX
Well we'll look at this one down the track a bit, got 8 month before I can even think about it haha.
Might be able to purchase bits as I go
- vipfto
Re: c3rbera's GPX
Sweet anyway back on to rubys thread we kinda hijack it
- c3rbera
Re: c3rbera's GPX
I'd like to see this supercharger project happen just quietly..
And don't worry, I managed to unleash hell on another thread today, hijacking is fine aha.
Not too certain the pod will fit in the factory box, I'll take it off and test it at some stage anyway but I think it's a little too wide.
Liking the yellow too, it's different.
Piping to the throttle body should be simple enough, the air feed would take a flexible pipe?vipfto wrote:Now just need to remove factory air feed and replace with ram and maybe use factory box with new less restrictive pipe to throttle body
Yep! 2 for the extender, 1 for the stock pipe. It sounds amazing! Done nothing to performance (if anything probably gone backwards with the hot air) but if only for the sound it was so worth it haha.Shhtuart wrote:Did I send you 3 of the ring clamps?
Re: c3rbera's GPX
- kiz
- SA Coordinator
Re: c3rbera's GPX
You do realize that if this project does go ahead AND is successful, it's going to be myself and Tim; and our struggle for powerc3rbera wrote:I'd like to see this supercharger project happen just quietly..![]()
- c3rbera
Re: c3rbera's GPX
Kids.kiz wrote:You do realize that if this project does go ahead AND is successful, it's going to be myself and Tim; and our struggle for powerc3rbera wrote:I'd like to see this supercharger project happen just quietly..![]()
Turbo has higher peak power no? Or are we looking at something more equal considering the management?
Re: c3rbera's GPX
More potential for power with a turbo.
Supercharger however is always on boost, rather than certain range.
