RPW extractors, good bang for buck?
FTO338
Post by FTO338 »
I agree to what Eric (MADFTO) said, & I've also got RPW extractor. I've already gave my good & bad points of the product, so i don't have to repeat myself here.
But what i like to point out are that not everyone had the time & money to do two dyno everytime they put a mod in. Which what steve had ask everytime someone put a review on product (especially RPW).
Don't get me wrong, I definitely agree that we need to proof what we said, & not just some "feel", but how realistic would it be that people can do two dyno for every mod???
I think thats the original point GWIDO were try to make.
ONCE AGAIN, I'M NOT ON ANYONE SIDE, I'M JUST GIVING MY POINT OF VIEW, AS THIS IS A PUBLIC FORUM. :D
D-TRAIN
Post by D-TRAIN »
But the question I would like answered is whether or not the RPW extractors/downpipe combo has the same hissing noise experienced by the UAS counterparts??
From FTO to EVO......
MADFTO
Post by MADFTO »
*smiles* need more information. I'm not experiencing any hissing at all but my definition of hissing might be different to yours =)
Need more info along the lines:
Is it constant?? Does it get louder as RPM climb?
Where does it appear to be coming from?
Are there a specific set of criteria that you've figured out to make it occur or is it random?
RichardH
Post by RichardH »
In neutral, rev engine to 4000rpm.
Throttle off. Let revs drop back to idle.
Between 4000rpm and 3200rpm, there was a 'bees in a can' sound coming from the exhaust system.
I wrapped the flex joints in header wrap, and the bees got much much quieter.
- Rich
MADFTO
Post by MADFTO »
Hmmmm, I've never heard of that happening before I don't think =P
It sounds wierd =)
What size piping do you have after the cat?
Just sounds a bit wierd, sounds like some sort of turbulence at lower rpm. I don't know though, it's always hard when you can't hear it for yourself =P
G1
Post by G1 »
RichardH wrote:In neutral, rev engine to 4000rpm.
- Rich
i do notice the hissing noise around that rev range, but dont notice anything on throttle off... what is this header wrap? and where can i get it from?
oh nevermind i saw the other post :D
Disrespect is easy. Respect is the difficult road to take.
RichardH
Post by RichardH »
MADFTO wrote:What size piping do you have after the cat?
Everything else is stock. There don't seem to be any gasket leaks. I put it down to the flex joints...
- Rich
GWIDO
noises
Post by GWIDO »
I dont seem to get that noise from my GPX.
It is manual GPX, RPW extractors, throttle body and CAI, FPR.
There is a slight noise from the CAI though.
FTO338
Re: noises
Post by FTO338 »
GWIDO wrote:I dont seem to get that noise from my GPX.
The only mod i'm different to yours is throttle body, while i ported & polish, but yeah my CAI is bloody loud after the extractors. Is like a vaccum cleaner on the lowest power 8O I guess is a good thing that its sucking lots of air :D
MADFTO
Post by MADFTO »
*laughs* I think quite of a few of us can attest to the vacuum cleaner effect =) I'm guessing most of us have pods =)
I kinda miss my old exhaust note =PPP I'm guessing the general populous isn't though =)
Honestly, I'm stumped, I need to hear it myself =)
FTO338
Post by FTO338 »
Yeah i know what you mean with the pod filter, but this is much louder then just with just pod. Heheheh then again i guess u use to it, since you had your extractor & pod for a very long time now ehehehe
ruchi
Post by ruchi »
just a thought...
The sucking sound occurs because the engine is requiring more air and in turn more air is being sucked through the air filter. As a larger volume of air is sucked through the filter the speed at which it is sucked through will increase. As the speed of the air increases it becomes audible, producing the sucking sound, it's the same sort of concept as only being able to hear the wind when it is blowing a gale.
With increased air speed comes more turbulance and likewise less efficiency with the air filter. i.e. more dirt and stuff will get sucked through the filter because the speed at which it is travelling is higher.
So if you're getting this sucking sound, it may pay to get a larger air filter. The increased surface area will allow the same amount of air through, but at a lower pressure, thereby decreasing the amount of air turbulance and increasing the cleaning efficiency of the filter. The sucking sound will also decrease.
MIVEC is My Friend :D
GWIDO
filter
Post by GWIDO »
took my pod off, totally caked in crap. guess that would have something to do with it. can't wait to see some performance improvement when its clean. need to design something to protect it a bit me thinks....
so from what you are saying ruchi, there is a restriction somewhere in the UAS downpipe that is making it hiss? or did the flex joint thingy totally solve it Rich?
The RPW extractors have a single, very large, maybe 3inch, flex joint in them that is extremely hard to make flex. Maybe the downpipe could be redesigned to include this in the next production run. From what I've seen the down pipe has two quite (comparitively) small flexs, is this right?
smorison
The Godfather
Re: filter
Post by smorison »
GWIDO wrote: so from what you are saying ruchi, there is a restriction somewhere in the UAS downpipe that is making it hiss? or did the flex joint thingy totally solve it Rich?
The two flex joints mean that each engine pipe (post extractor) can flex whichever way the engine moves....
there isn't a restriction that we know of... we actually have a few larger diameter ones floating around from prototype testing with different ID's to see if there was a gain - there wasn't. (these would be perfect for a turbo FTO not a NA FTO)...
the hissing noise is a reverberation that is accentuated depending on the aftermarket exahust that a car has... some have none some have heaps....
the engine pipes were designed using standard calculations for exhaust velocity at varying engine RPM to design a system that was as efficient throughout of much of the rev range as we could make it...
it's easier to design one for a car that spends most of it time above 400RPM ;) hard to develop one that works from 750 - 8500...
ruchi
Re: filter
Post by ruchi »
GWIDO wrote:so from what you are saying ruchi, there is a restriction somewhere in the UAS downpipe that is making it hiss?
huh?
my last message was about air filters not downpipes.
TimmyD
Re: filter
Post by TimmyD »
huh?
LoL :D
GWIDO
sorry
Post by GWIDO »
sorry ruchi, was using your explanation to try and explain to myself why the uas downpipe makes the noise Richardh was talking about. guess i got yous lost in my train of thought.
What i was trying to say was that if a pod makes a noise due to a restriction, then would extractors do the same thing? ie is the noise in the downpipe due to a restriction??
thanx
ruchi
Post by ruchi »
generally speaking, wherever there is a restriction pressure will increase, however with the UAS piping the hissing issue occurs when people back off on the accelerator (big pressure decrease) not when they are accelerating (big pressure increase). So I don't believe there is any restriction issues with the UAS pipe, in fact it could well be the reverse, perhaps it flows out so well that when the pressure does decrease (foot off the accelerator) there may be a void or low pressure that creates suction.
Who knows, I'm just speculating.
ruchi
Post by ruchi »
I posted this same message in another thread covering this same topic, but as there are multiple threads going, I'll post it here too...
in looking at the dyno graph for the UAS pipe, the biggest difference is at the top end. So in short, if you want more pickup in the mid-range go for the RPW extractors or if you want more in the top end then go for the UAS pipe.
This also quells any issues as to which one is better, as they work in different rev-ranges. :wink:
GWIDO
thanks
Post by GWIDO »
thanks
