Danny's And Jeff's 6A13 turbo Conversions
- dannyboyau
- dannyboyau
yes and no, you wouldn't break your driveshafts, you would break something else, which is more expensive to replace.GPXXX wrote:i don't suppose there would be any significant benefits in cryo-treating the driveshafts James? ..or perhaps get a custom billet item made for it?
Once you treat the drive shafts or put stronger ones in. Something else will become the weakest point, could be the gearbox, clutch, diff. These are much more costly to repair or replace and much more work involved.
Driveshafts can be easily changed. In an hour or two you could have the car going if you had a spare set.
In laymens terms the driveshafts would be the driveline fuse.
- dannyboyau
Jeff
No luck with the tip box. So manual it is.
I found a manual half cut, not sure if it is a gr or gpx for your flywheel , but the place is called Asian auto spare at slacks creek. 07 3208 0133.
I am just waiting for the custom built drag clutch then the car will be ready.
Hopefully early next week.
( how many times have I been told that !!!!!!)
Jeff
Jeff
- dannyboyau
- dannyboyau
Jeff
Just spoke to them today.
All is well. They had to redo the rear exhaust manifolds (more ceramic coating) and redo the dump pipe. The clutch is in and the box is in. They started it up today, and by god it actually goes.
Tidy up tommorrow, and finish off the internals.
Dyno tune on Friday, and hopefully pick it up then.
If all goes well, I should be at Qld Raceway on Mon, for a performance driving day, which I paid for 3 months ago.
Jeff
Jeff
- dannyboyau
Jeff
F#$K , F#$K , F#$ !!!!!
All finished, went down to the dyno and as mentioned before there was a bit of engine noise. Before this though we had taken off the rocker cover and oil was being pumped through the lifters so this wasn`t the problem. We took it up to 16PSI and only 6000rpm and got 350 hp, but the engine noise was getting worse. So we stopped ane drove it back to the workshop. The noise was getting bad by thie stage. After letting it cool down we started it again and there was the sound of a piston hitting a valve.
So there it is all finished but with a stuffed conrod, and now possible piston and valve damage. The workshop are blaming the wreckers who I brought it from, stating that they should replace it. But I know true well they wont and probably don`t have another 6A13 in stock.
I would have thought they would have pulled the engine down before transplanting, but they say they did a compression test, did a general service and replace all the belts. They routinely do not check the bottom end. So they did not check the bearing.
A question to all, Is this standard practice, I would have thought checking the bearings would be compulsory before you put in an engine, especially one that is going to make so much power. Any input would be greatly apriciated, as I think I am about to enter into a huge fight.
Danny, all your internals, were they off the self or did you have them especially made? and can you give me the details from where?
I`ll give you a call tomorrow if you don`t mind.
My first thought was to rebuid this engine with strengthened internals, but the mechanics were reluctant to do so. They want me to by a new engine so they can just bolt it in. And sitting not 20 feet away is my perfectly good 6A12 that now will not fit back in.
Needless to say, I would be surprised if you could not hear me swearing in Melb today wilst I was arguing with the mechanics. 8 months now and still no sign of my baby back.
If anyone works for a garage or workshop, or is talking to one, I would apriciate the feedback on whether people routinely check bearings on engines before transplanting.
Jeff
P.S. Danny as you can guess I didn`t have time today to check out the clutch for you but it is from a Brissy company NPC ( I think ), it is rated to 1000hp and guarenteed against slipage.
Jeff
- dannyboyau
wow i would be pissed too
when buying an engine they usually start it up before they sell it to check it out when it is in a halfcut. Some give warranty, i would go back and speak to them and get them to ring the workshop where you had the work done to confirm it had the noise from first start up.
They don't physically check bearings ( bigend and mains ), i am assuming that there is a bottom end knocking noise now.
the workshop did compression test and changed the belts, sounds like they did everything right. They must have the timing belt on right to pull 350 hp.
Give us a ring
Give us a ring
- Luca
Jeff
Thanks Guys,
I have spoken to a good friend who is a mechanic, and received some good news. Even if the wreckers wont come to the party, as I`m sure they wont. He can rebuild the engine for me.
He states that yes, workshops routinely check compression and oil pressure but dont pull down the bottom end. But he does think that as soon as it was first started and there was a noise the engine should have been pulled out and checked before going on.
So the plan is;
1. Ring the wreckers and see if I can get a replacement. ( wont happen )
2. Share some of the blame with the workshop and offer some of the final payment, then onto a towtruck to my friends garage.
3. Call a lawyer.
Neither the wreckers or workshop have charged GST so I`m guessing they are both doing this on the sly. So probably I will have some negotiating power to get some money back to go towards my engine rebuild.
So depending on the damage done and how long to wait for parts, my car is a long way off yet. But hopefully With the money I get back from the others I will have a fully rebuilt with forged parts engine which should be bullet proof.
Look out that 500hp mark.
Jeff
P.S. Is anyone on this forum a Lawyer or can recomend one?
Thanks.
So the plan is;
3. Call a lawyer.
Jeff
Thanks.
- RichardB
Jeff
Latest Update.
My mechanic friend doesn`t have to much time at present so it would take months to get it going, so I decided to go another engine. Of course the wreckers didn`t have another 6A13, but luckilly someone came to my aid.
I was talking to Danny about my options, and he stated he had a spare 13.
Yahhhhhhoooooo.
After a few phone calls, it arrived in Brissy on Thurs am. It was supposed to arrive Wed so when I rang the workshop they hadn`t received the engine yet, so a few phone calls later, I found the engine in the Bris depot, with the guy asking when was I going to pick it up. So finally it should have arrived in the workshop Frid, pull it down, transfere a few bits and pieces from the other engine, send the old one back to the wreckers, and hopefully have my car on the road by mid next week.
If the wreckers won`t refund my money I`ll give the old engine to my mechanic friend who can take his time rebuilding it.
To all those thinking of doing a turbo/ transplant. Don`t!
Jeff
Yahhhhhhoooooo.
Jeff
- FTO338
Well at least your car should be up & running by next wk, which is a great news.
Just out of curious how much had you spend by now?
Jeff
- dannyboyau
hi everyone
seems that someone by the name of ajobbo has sent me an email asking about the 6A13 conversion, and when i try to read the email, my email program crashes.
If you read these forums ajobbo, please post your questions here as i cannot reply to your email.
maybe you might need to check your email program for viruses or something.
cheers
will be happy to answer your questions, but please don't email me if it is going to crash my system
cheers
