smorison wrote:danny,
how much is 0.5mm capacity wise???
did you do this to the 6a12 or 6a13???
what sort of cost is associated with this???
.5mm equates to an increase in capacity of 31 cc total for 6 cylinders
I did this to the 6A13 because i scored to block when I detonated the pistons.
Total cost for engine rebuild, with custom forged pistons and rods, heads ported and ceramic coating of valves, combustion chambers, exhaust ports and pistons, block decked and rebored, torque plate made for block rebore, full engine rebuild gasket and seal kit, new water pump, new timing belt, new timing belt tensioner and idler bearing, crankshaft bead blasted and polished, modified sump, new injectors, custom made fuel rails, engine rebalance, labour. will cost just over 10 K
