Moving Battery
efteoh
Post by efteoh »
ive done a few searches for this allready, but found nothing that really answers it. is there a way i can get 2 guage cable in through thte firewall. theres mention of a port behind the battery and infront of the glove box, but it doesnt look big enough,
where did you guys route it?
dannyboyau
Post by dannyboyau »
i ran mine under the car and then drilled a hole in the floor of the boot
efteoh
Post by efteoh »
hmmm, anyother ways, im trying to keep it in the car,
efteoh
Post by efteoh »
under closer examination, there is no F#*&^#ing way im getting a 2 guage through that gromet. im thinking about using three or four 8 guage cables and run them in paralle, what do you guys think?
dannyboyau
efteoh wrote:hmmm, anyother ways, im trying to keep it in the car,
why
Boris
Post by Boris »
dannyboyau wrote:i ran mine under the car and then drilled a hole in the floor of the boot
Wow. Danny, would you have pics, or a better description of how you sucured the wire under the car. . .
Also, i was thinking of drilling a hole through the firewall, as all the grmmets are way to small for me, I need to also push through a 10c sized oil temp sensor from the inside.
efteoh
Post by efteoh »
anyone else know where i can get a battery box from, i checked out the ones at super cheap autos and they were just crap, anyone know where else to look? i'd like it to fit in the tray in the boot
FTO338
Post by FTO338 »
Josh have u try Repco, Burson & the like????
efteoh
Post by efteoh »
are you stalking me kev? HAHAHA
thanks, i'll try repco. i forgot all about them
onnzo
Post by onnzo »
Try marine stores... they will be a lot cheaper too.
Mike
FTO338
Post by FTO338 »
efteoh wrote:are you stalking me kev? HAHAHA
Mate if i'm stalking u, u be dead by now. :twisted:
Boris
Post by Boris »
The problem that I found with most battery boxes, are that they are all too big! I haven't found a marine battery box, but all the ones in super cheap etc. are way to big, for like an Odyssey battery or something.
And you may think, get like some wood and put it in the box, but no, because there is limited space in the boot, especially if you want to put the box as close the the side. Well, that what i want, anyway.
Can any one say like a minumum battery requirement like CCA, aH for a deep cycle battery, to be placed in the boot? like with decent 160Amp cable etc? There are some small batteries going on ebay, but i think they may be too small...
:arrow: http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 28308&rd=1
:arrow: http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 26160&rd=1
:wink:
RichardH
Post by RichardH »
Can I ask what your motivation is for relocating the battery to the boot?
- Rich
Boris
Post by Boris »
Hm. i donno about others, but mine is simple.
1) It will make my engine bay more nicer.
2) Battery will stay cleaner
3) Intake Piping / CAI
With the intake piping, I have the UAS pipe, and that get's squished and slightly touches the supporting rod for the battery.
I'm planning to get an thin alluminum intake piping made up, mimiking and extending the UAS pipe further into the corner. (I have a freind in the business). This pipe wouldn't be able to bend, and the battery will get in the way.
Then I will probably try and get like an ARC typy intake box.... made up... but that's another challange...
efteoh
Post by efteoh »
i guess my motivation is similar to that of boris
1. free up room in the engine bay
2. makes installing ICE easier
3. another type of intake? ;)
if you have a look at e36 and above BMW's they have the battery in the boot secured but not sealed. i guess manufaturers can get away with a lot more, eg HID (with out washers and levelers)
any more ideas about small battery boxes? i was thikning about a marine shop but they will probably rip me off big time. :(
RichardH
Post by RichardH »
Okay, thanks for that.
If your battery is getting on a bit, and you're primarily after the induction/space benefits, you could look at replacing it with a low profile Odyssey battery. A custom induction pipe will go right over the top of it.
Here are pics of my setup... From the top:
...and from the front:
I don't know the average cost of boot relocation, but weigh it up against the cost difference between a new standard battery and a$270-$290 Odyssey (the smallest one that is warranty-approved for using in cars).
The write-up for this entire installation is here:
http://www.ftowa.com/html/workshop/workshopart10.html
Hope this helps!
- Rich
efteoh
Post by efteoh »
that was where i got the insiration from richard :)
but i was thinking of shorting the intake pipe to where the battery, and thats why i was also asking about the paint. :) aparantly shorter intake pipes give you more gain. wooo hooo 0.00001 kW extra! :lol:
RichardH
Post by RichardH »
I did read somewhere that the ideal situation was for a certain volume of air (as a percentage of engine displacement) to be present between the intake plenum and the filter. Apparently it improved throttle response, and is the reason why a pod filter isn't (often) stuck straight onto the throttle body, hehe.
Good luck with it!
- Rich
efteoh
Post by efteoh »
ahhhhhhhh, the other side of the coin
thanks richard. well back to the drawing board for me...:D
