BJK's FTO #2: The GPX-R
Re: BJK's '95 FTO GPX #2!
You can't nutsert it because then he will have to run a thinner non oem bolt.
This fucked nut will go on for 17 pages. I'm out.
Just drill it out and use a bigger nutsert.silverGPX wrote:You can't nutsert it because then he will have to run a thinner non oem bolt.
"What size thread should I use if I wanna run a silver nut but don't want it to rust it has to fit perfectly but also look good and if I use this kind of nut what about the bolt for it and can I mig it or tig weld it? Maybe I will just stick weld it...Bennoz wrote:This fucked nut will go on for 17 pages. I'm out.
*500 photos of a bolt*
- bjk
- Totes
Except it won't 'cause the fucker is getting welded and that's that.Bennoz wrote:This fucked nut will go on for 17 pages.
Just put some JB weld on the end of the bolt and hold it in place til it dries.
- bjk
- Totes
Will just seal it with a generous helping of semen.Vectose wrote:Just put some JB weld on the end of the bolt and hold it in place til it dries.
Re: BJK's FTO #2: The GPX-R
Sounds like a waste of perfectly good semen.
- bjk
- Totes
- bjk
- Totes
The car has sensed that Tim is leaving and is trying to convince him to stay by being cooperative.
Main crank pulley/harmonic balancer, new passenger CV joint, and tie rod and steering boot done last night. I think I have located the source of the clunking in the back, because the exhaust is sitting hard up against part of the chassis just before the rear control arm. Doesn't really explain why I think I hear it on the drivers side at the back, but it must be it.
Preparing to throw wads of cash at car. Fortunately the three businesses I want to use are all located within the same square kilometre and two on the same block, hopefully I can just have the car go from one to the other and pay my dues at the end. HIDs and parker wiring at the first, floorpan welding and maybe a new cat-back at the second, and respraying and fitting the facelift bar and fenders at the last. RIP bank balance.
Floorpan welding? Why not just chuck an EVO floorpan in.
- bjk
- Totes
MAYBE I WILL mateVectose wrote:Floorpan welding? Why not just chuck an EVO floorpan in.
Oi, who changed the mate with an eight to 'mate'
It's Bens big penis. Was done many years ago to stop txt spking c*nts m9-1bjk wrote:MAYBE I WILL mateVectose wrote:Floorpan welding? Why not just chuck an EVO floorpan in.
Needs an update. Times have changed m7+1Bennoz wrote:It's Bens big penis. Was done many years ago to stop txt spking c*nts m9-1bjk wrote:MAYBE I WILL mateVectose wrote:Floorpan welding? Why not just chuck an EVO floorpan in.
Oi, who changed the mate with an eight to 'mate' :lol:
- bjk
- Totes
The problem is you'll never be able to eliminate all the mathematical possibilities.
Shut up m sqrt(arcos(0.438371146))
Not with that attitude.bjk wrote:The problem is you'll never be able to eliminate all the mathematical possibilities.
You can never calculate wankers, it's like trying to calculate what size rims will fit.
Bennoz wrote:You can never calculate wankers, it's like trying to calculate what size rims will fit.
