Ask and ye shall receive.silverGPX wrote:Dude...
You need pics of this.
Daniel's Rookie DIY FTO Build!
Re: Daniel's Rookie DIY FTO Build!
The only thing that worries me is that one of the spark plug leads doesn't quite sit properly in the rear bank. It doesn't go down as far as the other two.
It is the lead, not the spark plug hole but I have no idea as to why it won't go any further.. It should be OK as it is connected up with the spark plug fine but sits slightly high above the rocker cover.
Have tried other leads in that hole (lol) and they are fine and have tried that lead and it does the same thing in other holes (lol again).
Dude...
You need install of this.
Meanwhile, with regards to the spark plug lead.
Have you checked the seal along the bottom, could have become caught and won't now seal properly.
Had that issue with the chewed set of leads that were in the NX.
Install will be coming soon.. just need to get my flywheel machined and I think i'm just going to have to front up for a new clutch and it's right to go in.Astron_Boy wrote:Dude...
Seal is fine, no different to the other ones. Little bit confused but it should be OK.
Are they the stock manifolds? Why no extractors ? Surely amongst the gazzillion things you've bought for this car there's some ?
Standard manifolds yes. I do have a set of extractors here but they belong to vanadinite unfortunatelydestinationtoby wrote:Are they the stock manifolds? Why no extractors ? Surely amongst the gazzillion things you've bought for this car there's some ?
I do have a track exhaust with no cat or muffler though
Oh.Daniel2019 wrote:Standard manifolds yes. I do have a set of extractors here but they belong to vanadinite unfortunatelydestinationtoby wrote:Are they the stock manifolds? Why no extractors ? Surely amongst the gazzillion things you've bought for this car there's some ?
Nah I bought that for a mate.
I have a Kakimoto for street use and a straight track pipe, no cat or muffler for the track.
Noice
Someone come and do my steering rack boots and my release bearing...
I'm getting tired of replacing things
I'll supply infinite beer for the duration of your stay...
Daniel2019 wrote:Someone come and do my steering rack boots and my release bearing...
I'm![]()
Well yeah, basically...Vectose wrote:Daniel2019 wrote:Someone come and do my steering rack boots and my release bearing...
I'm![]()
I've spent too much time and money on this already.. just want the bastard running
Dammit where's my bestie when I need him!
Edit: Which brings me to my next point... how the f**k do I replace the steering rack boots and release bearing?
Undo tie rod ends and boot slips right on. If you count the number of turns you have to do to get each tierod end off, you should be able to get it approximately right when putting back on. You will need a wheel alignment.
If the gearbox is out, release bearing is pretty easy from memory. Just a matter of removing clip, slipping off old and replacing with new + a little grease (get someone to confirm this though as it has been a little while)
Alright no worries, i'll have a crack at it this arvo after I have a nap
Building cars is tiring!
Yep slides straight on and off with that clip.. Best to pull off the arm behind it and clean then re grease the little part where it joins while your at it.
Ah ok awesome.
Cheers.
Cheers.
Daniel2019 wrote:Ah ok awesome.
Cheers.
Anyone more knowledgable care to confirm?
Vectose wrote:Daniel2019 wrote:Ah ok awesome.
Cheers.
Was pretty much a quote from bennoz in my help thread dickhead......
destinationtoby wrote:Vectose wrote:Daniel2019 wrote:Ah ok awesome.
Cheers.
Vectose wrote:destinationtoby wrote:Vectose wrote:Daniel2019 wrote:Ah ok awesome.
Cheers.
Was pretty much a quote from bennoz in my help thread dickhead......Was only joking mate. I know it's correct.
why the unnecessary sh*t talk then
