Daniel's Rookie DIY FTO Build!
- rock_it
Re: Daniel's Rookie DIY FTO Build!
At least you know the engine is going to be fresher than anything you would have bought second hand though ... Similar to how well Aza's went when he got his back...
Sadly, even if a car is well maintained, it will always loose a bit of performance once the K's stack on...
- SchumieFan
A rebuild is when something breaks and you need to 'rebuild' it
Reconditioning is preventative maintenance...
That assembly still seems a tad higher than what I would have thought...
Probably easier I just quote my "wow, just wow" post from earlier...
- rock_it
Although a while ago ...
I had my Evo engine reconditioned, and forged internals done for about 5K... Granted it is a 4 banger, with more access to parts...
FixedSchumieFan wrote:A rebuild is when something breaks and you need to 'rebuild' it
Reconditioning is replacing all the internal parts with new ones; ie reco alternator = old alt with new internals...
Preventative maintenance is just servicing.
Find everything that you think is needed then send the list including links to the workshop and let them confirm before you purchase/order.Daniel2019 wrote:Also, have been told I need Mark 3 bearings (main, bigend, thrust)
Now, one would assume I click on the S3 option, correct? -
Crank (need x4) - http://www.camskill.co.uk/m3b0s9p7636/M ... ec_Engines
Big end (need x6) - http://www.camskill.co.uk/m3b0s9p7570/M ... TO_V6_DE3A
Now with the thrust bearing the only thing camskill has listed is thrust washers - http://www.camskill.co.uk/m3b0s9p48700/ ... st_Washers_
Or am I completely off course here?
...help me
Here's total list so far -
GASKETS, SEALS etc. http://www.camskill.co.uk/m3b0s9p5811/M ... V6_Engines
BELTS http://www.camskill.co.uk/m3b0s9p37116/ ... X_and_GPvR
BIG END SHELLS (s3 X 6)
CRANK MAIN BEARING SHELLS (S3 X 4)
THRUST WASHERS http://www.camskill.co.uk/m3b0s9p48700/ ... st_Washers_
PISTON RINGS http://www.camskill.co.uk/m3b0s9p9256/M ... _0_V6_DE3A
Have emailed it off to Nas just then so will await confirmation before placing the order.
What am I missing?
What am I missing?
Engine is finished!
Now to get it in the car!
- rock_it
SWEET!!!!!
Let me know if you need a hand with it.
I need a hand with itVectose wrote:Let me know if you need a hand with it.
Getting engine crane from the boss on Sunday and hopefully picking engine up Monday.
Sweet!
- Lawso
- Penis Fingers
- rock_it
That still sounds so strange to me...Lawso wrote:I can drive a rented ute if you need on Monday!
Just picked up the engine crane, picking up engine tomorrow morning
Yay!
Good stuff bestie, bet you can't wait to start it up and have it go vrooooooom
Cheers guys!
Yep, has been a long wait. Hopefully if I pick it up on Monday it will be done by Sunday 24th!PHIL069 wrote:Good stuff bestie, bet you can't wait to start it up and have it go vrooooooom
Daniel2019 wrote:Just picked up the engine crane, picking up engine tomorrow morning
?Daniel2019 wrote: Hopefully if I pick it up on Monday it will be done by Sunday 24th!
