The Suspension Thread
- AJ
FTO feels like a new car. It handled really well today, but the brakes let me down too early on in the fun stuff. I'm still nervous about pushing harder due to having crappy suspension for so long. I've taken a few corners I know well it's amazing how much quicker it can go through them now. Well worth the money. Looking forward to the brake upgrade next...
- Gholdwayne
ben!! what was the suspension shop name of that friend of yours whome i got a pretty good quote on for the lovell springs + kyb shocks ? Iv been searching for that post for 3 days now... couldnt find it at all... im getting my suspensions done around mid march thats why, cheers
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
FTO[For The Orgasm]
Here's a neat upgrade to stiffen the rear of your FTO up
Use the EVO I,II or III rear trailing arms. The Evo versions are almost identical to ours, however they have a plate welded over the base of the arm to stop it flexing.
They are a direct replacement for GPX & GPvR. You will also fit the GR, however, you will need to either change to Mitsubishi GTO droplinks, or change to a GPX / GPvR swaybar. Personally I'd go for the GPX/GPvR swaybar as its thicker than the standard GR unit. I've already upgraded my GR swaybar to a thicker whiteline unit, so will need the GTO droplinks.
The part numbers are LH - MR197609, RH - MR197610
Here's a standard FTO arm:
Here's the EVO arm:
Here's the GTO droplinks:
GTO droplink part numbers:
4056A039
MB584467
MR131733
Here's the EVO arm:
4056A039
MB584467
MR131733
- zuihoujueding
Re: The Suspension Thread
wow great find!!!! thanks ben!
do you feel andy difference in weight between the two?
- mr-charisma
Re:
nice find ben .. might try that one as well
- aza013
- NSW Coordinator
I want somthing like these
Fits Lancer/Mirage 96-02 made from the highest grade alloy 6061.
Do you think they would fit Ben?
- mr-charisma
how much aza?
Be ok if one of the ends on those was 90 degrees around..
- aza013
- NSW Coordinator
But both ends are the same way as the ones you posted up?
I really shouldn't have had that big scotch at the end of last night
- aza013
- NSW Coordinator
I am looking into the cost of them now, will get back to you with cost.
- Doobs
Hey guys.
Probably should've posted in here 1st.
viewtopic.php?f=21&t=20447&p=227132#p227132
Any help or recommendations appreciated.
- Valandis91
hey there ben, after a little incident my drivers side rear wheel has more positive camber than the other side. what wouldve bent? the trailing arm? my mechanic tried fiddling around to bring it back like the other side but the adjustments didnt do much. what does it sound like i have to replace?
- vipfto
bent strut, one of the rear arms usually the cause of that
- Valandis91
- aza013
- NSW Coordinator
Just got a price on these they are at this time $300 + postage or free pickup.
I will see if I can get a better price for a GB.
BUT the big thing is to see if they fit and work on the FTO's befor any one gets them
- zuihoujueding
they really look like art
- aza013
- NSW Coordinator
some more pics of them, they are available in Titanium and blue.
