Shortening Gear Stick
HiRAEdd wrote:I have cruise control on the gear knob (see post higher up), it made the gear stick higher, I just want to bring it back to stock height.
Well, I spose you could cut it down. Just need to bear in mind that the stick gets fatter further down & if you were to cut a thread into it, it would be a bit larger in diametre...
Euro wrote:are there any other short shifter kits available to FTO? Seems that you can get one for a wrx etc for about $150 and its more like $380 for fto...
I understand there is not the same market to FTO's but wondering if there were locallly made alternatives?
I believe RPW do them for $250, but you have to send your stick to them for modifications... :?
Mitsiman
Approved FTO Australia Trader
Post by Mitsiman »
RPW does manafacture a rally spec short shifter kit for the FTO and other mitsubishi vehicles.
Our unit will lower the height of the stick by approx 1" / 25mm, will shorten the throw of the shifter by around 50% forwards and backwards but also sideways unlike any of the current shifters on the market which only shorten them forwards and backwards. Our shifters you can go straight from 2nd to 3rd on a diagnall and overall will improve the gear shifting feeling on the vehicle removing that notchiness.
We also do teh shifters on an exchange basis so you get our modified one, fit it up and return your stock one back to us.
These retail for $220.00 AUD$ for a modified shifter plus core charge and freight.
Takes around 30 minutes to fit and no modifiying required.
we have been selling these for many years and they are a well known product in the mitsubishi market australia wide.
There you go Euro - straight from the horses mouth!
Thanks Mitsiman! :)
