Project FTO VR4
Rob Furniss
Re: Project FTO VR4
Post by Rob Furniss »
It looks insanely tidy Daz, good work. I knew you'd do a neat job after your previous supercharger install which was very tidy too.
Re: Project FTO VR4
I might be blind and have missed it, but what did you do with the issue of the front turbo interfering with the clutch slave?
dazjb
Re: Project FTO VR4
Post by dazjb »
I had to modify the actuator bracket to move it away from the slave cylinder and then bend the arm to reach to the wastegate on the front turbo.
Re: Project FTO VR4
Ah yep! Think that's what Bennoz has done as well. Pictures help my brain work with these sorts of things.
Re: Project FTO VR4
Yeah, I bought stiffer actuators, came with longer arms, cut & shut them into place & welded up a bracket that holds both the clutch slave & the actuator.
DODO``
Re: Project FTO VR4
Post by DODO`` »
Wow, just wow.. good work mate congratulations!
Sent from my D5833 using Tapatalk
Re: Project FTO VR4
What exactly did you do to the radiator fan Daz? Are you just running the one fan or have you since put a second in?
dazjb
Re: Project FTO VR4
Post by dazjb »
I have a spal push fan now fitted on the other side of the rad ...
Sent from my SM-G935F using Tapatalk
Re: Project FTO VR4
Ah yeah. Does it do enough of a job in traffic, or do you try to avoid taking it out much in peak altogether?
dazjb
Re: Project FTO VR4
Post by dazjb »
It gets the temps down real quick. It's a Spal VA01-BP70/LL-36S so it moves a fair bit of air.
Don't have to worry too much about peak times in the UK at this time of year .. It peaked at around 14 degrees celsius today!
Re: Project FTO VR4
Yeah it was cold here in Brisbane today too, got down to a low of 34degrees Celsius
