Fans.
c0n13oX
Re: Fans.
Post by c0n13oX »
So it could be pretty much anything.
Re: Fans.
Basically :lol:
I'd start at temp sensors and a good radiator/cooling system bleed if you haven't already and go from there.. is all pretty basic stuff though.
c0n13oX
Re: Fans.
Post by c0n13oX »
Where are the temp sensors located dan? And where would I be able to get a replacement?
Re: Fans.
Shhhhhhhhhhhtuart has them I think.
They're around the thermostat housing. One is back towards being in line with your battery terminal and one is a little further toward the front of the car.
Re: Fans.
Replaced it on saturday so it can't be that. Unless the connection is actually dodgy.
Re: Fans.
Which one though? Or both?
In that case may be fan switch or something but doubt it.
c0n13oX
Re: Fans.
Post by c0n13oX »
Only does it when stopped, or slow traffic. So im thinking maybe a blocked/dirty radiator.
Re: Fans.
Well yeah, fans usually not needed at speed. Same as smurf.
c0n13oX
Re: Fans.
Post by c0n13oX »
Fans are fine. Turn on when too warm. I just want to find out why its getting hot
Re: Fans.
Get mechanic to chuck a temp gun on it and see if it actually is getting too hot or if gauge is incorrect.
c0n13oX
Re: Fans.
Post by c0n13oX »
Yeah, might do that. Thanks for your help though
c0n13oX
Re: Fans.
Post by c0n13oX »
Mechanic said will most likely need a new radiator.... whereabouts would be the best place to get one?
Re: Fans.
c0n13oX wrote:Mechanic said will most likely need a new radiator.... whereabouts would be the best place to get one?
Has he looked at the car and checked the flow of the radiator?
I hate when people will tell you it is radiator related without even looking...
c0n13oX
Re: Fans.
Post by c0n13oX »
Took it to a radiator guy, explained what's happening and he said it's most likely fan related.
Re: Fans.
All the aluminium radiators on the net are manual ones, regardless of what they tell you. I found out the hard way. It worked out cheaper to buy a manual one and hook up and external transmission cooler.
c0n13oX
Re: Fans.
Post by c0n13oX »
Would having no AC affect it?
Re: Fans.
c0n13oX wrote:Would having no AC affect it?
Doubt it. Separate systems.
Re: Fans.
Did he check it with a temp gun?
c0n13oX
Re: Fans.
Post by c0n13oX »
Not sure.
Re: Fans.
We could guess all day mate, go see a decent mechanic.
