HELP engine oil leaking!!!
MADFTO
Post by MADFTO »
*laughs* I've had that happen before . . . even with heat coated extractors =)
smorison wrote:
MADFTO wrote:Man, if you hate battery acid, you're not going to like it in the boot . . .
I'd suspect that the rear end of the car would pull more Gs than the front would . . . =)
true but i won't have a battery getting excessively hot and pissing out battery acid when i'm on the race track....
even when driving the FTO around normally the engine gets damn hot. So becuase everything is so cramp etc.
A lot of cars have heat shield around their battery, maybe it would be wise to invest in one?
MADFTO
Post by MADFTO »
My engine bay doesn't really get that hot anymore, there something to be said for heat coated extractors =)
ruchi
Post by ruchi »
handy hint 102
To improve the removal of hot air, you can remove the rubber seal on the inside of the bonnet that runs along the entire width of the bonnet up near the windscreen. :wink:
MIVEC is My Friend :D
