LOLBennoz wrote:That's not the wiring causing that mate, it's your front barObsidianRadio wrote:My static and feedback is pretty fucked at the moment!aza013 wrote:It's not doggy running wires down each side of the car, as you should run power down one side and RCA/ speaker wire on the other side. This prevents static/ feedback into the speakers.![]()
Car Audio Installers
Re: Car Audio Installers
The Veilside bar is lifting the front of the car and causing too much wind resistance on the underbody which gets turned into static electricity, thus messing with your amps.
Get rid of the Veilside front bar and all your problems will be solved.
- ObsidianRadio
Explain why it was fine for the first six months of owning the carVectose wrote:The Veilside bar is lifting the front of the car and causing too much wind resistance on the underbody which gets turned into static electricity, thus messing with your amps.
![troll :troll:](./images/smilies/icon_troll.gif)
On another note...
![Image](http://i1198.photobucket.com/albums/aa457/choleracol/conspiracy-keanu.jpg)
- vipfto
AGREEDVectose wrote:The Veilside bar is lifting the front of the car and causing too much wind resistance on the underbody which gets turned into static electricity, thus messing with your amps.
yup, that's the issue!vipfto wrote:AGREEDVectose wrote:The Veilside bar is lifting the front of the car and causing too much wind resistance on the underbody which gets turned into static electricity, thus messing with your amps.
