Flashing N Still !!!!
- King hit kiz
Re: Flashing N Still !!!!
Alright cheers, i'll try that but i seriously have no idea how to change it... :S
Like i understand what to do, but what i would have troubles with is where do you loosen the bolts to drain it ? I know the filer is the near the input sensor and you fill it back up using the dipstick tube, and the hose is also near the input sensor.
Am i right there ?
Also what type of A/T fluid should i get ? Dstock was telling me FTO's have a certain one they like.
Am i right there ?
Hey King hit kiz, you are getting tag team help on this forum
silverGPX.....tagged.....PHIL069.....tagged.....Astron_Boy.....tagged.....
- King hit kiz
So i don't have a jack or axle stands.... :/
So i rang up the local transmission shop in Nowra and they tel me they won't touch my car because it is an import, and the only other tranmission shop around here aswell was closed, left a message at 10am and never got a phone call, so at 3 i went up there and was closed ):
Your right there PHILO69 but you forgot Bennoz after Astron_Boy
As a thought to those who might know.
If his gbox is screwed or whatnot, and his sensor takes 30 odd minutes to go into limp and detect its screwed, if he put it other sensors and it picks it up and goes into limp mode straight away, would that not suggest that the new ones are in much better condition/not effed as they pick it up and act straight away rather than giving the impression that they are worse because they dont 'last as long' as the other ones?
If the radiator was cooling the fluid correctly (heat transfered from ATF to coolant) then why is the fluid brown and burnt? If the radiator is full of grime/corrosion then the heat transfer would not be efficient enough to cool the ATF. If the ATF heat transfer unit inside the radiator or pipes from transmission to radiator are blocked, then the ATF would not have efficient flow to cool.Astron_Boy wrote:I would not say the radiator has any issues.
As transmission fluid is not of the same chemical make up as coolant, it is unlikely that there is a blockage for the oil to not be cooled.
I would assume that is correct, I think his transmission electrics are cactus/fried and that's why I don't believe that a fluid change will fix his issues, I am hoping I get proved wrong........but time will tell.Taz wrote:As a thought to those who might know.
WATS ALL THIS FKN SPECULATION, CHANGE THE f**king BOX OIL U TWIT.
- payaya
Why brown and burnt? Torque converter slipping, clutches slipping, pump shot, etc etc. Even with a 100% working cooling to the transmission a stuffed transmission will always burn the oil.PHIL069 wrote:If the radiator was cooling the fluid correctly (heat transfered from ATF to coolant) then why is the fluid brown and burnt? If the radiator is full of grime/corrosion then the heat transfer would not be efficient enough to cool the ATF. If the ATF heat transfer unit inside the radiator or pipes from transmission to radiator are blocked, then the ATF would not have efficient flow to cool.Astron_Boy wrote:I would not say the radiator has any issues.
As transmission fluid is not of the same chemical make up as coolant, it is unlikely that there is a blockage for the oil to not be cooled.I would assume that is correct, I think his transmission electrics are cactus/fried and that's why I don't believe that a fluid change will fix his issues, I am hoping I get proved wrong........but time will tell.Taz wrote:As a thought to those who might know.
2 flashes a second while driving is over heating. 1 flash you need to look at your sensors.
All this passionsilverGPX wrote:WATS ALL THIS FKN SPECULATION, CHANGE THE f**king BOX OIL you TWIT.
Like they say....."Everyday is a school day"payaya wrote:Why brown and burnt? Torque converter slipping, clutches slipping, pump shot, etc etc. Even with a 100% working cooling to the transmission a stuffed transmission will always burn the oil.
- King hit kiz
I'm going tooo !!!!! I'm just sick at the moment as well.
And i only get 1 Flashing N while I am driving ?
And you gotta love it
2nd that of what gpx and paya said!
***manually typed in using safari on my f**ken iPhone.***
- King hit kiz
I changed the fluid today and it hasn't gone into limp mode yet and it's running heaps smooth now
Hallelujah!
- King hit kiz
Also lets just say i hope my engine bay liked being sprayed today too :l
I picked the burnt fluid (I could smell it from here
I am always reminded to KISS (even in this very thread
CHANGE THE SENSORS!!
silverGPX wrote:CHANGE THE SENSORS!!
- payaya
Bet the problem comes back! 1 hertz is a sensor fault, so I doubt changing the oil will fix it.
TPS?payaya wrote:Bet the problem comes back! 1 hertz is a sensor fault, so I doubt changing the oil will fix it.
