Leather Seat Covers - You'll wanna read this
Re: Leather Seat Covers - You'll wanna read this
It looks a little loose in the top section, did that tighten up at all?
- rock_it
*SIGH*
rock_it wrote:
Only problem I have found is:-
1) they didn't cut the centre out, so you loose the harness holes. But in looking at the seat, I kind of like it.
2) they dont have a sleeve in the back of the cover, for a metal rod to slip through and pull it right into the base.
We pinned the seat from the outside, and the material pulls in nice and tight..
So next step is to see if I can do that myself, then communicate how to do it in Indonesian..
Oh, I'm sorry, I didn't realise that because it didn't have the sleeve at the back for the rod to slip through it made the whole top front section loose.
When you said it pulled nice and tight I thought that meant you had fixed it and not that its still loose fitting around the seat.
- rock_it
Yep... Basically there is a square base made out of a metal rod. This goes around the middle of the top section. Right near the edge of where the bucket sides meet the centre of the seat. This then has hooks that tie down the seats material to the metal rods which are built into the foam.
Once attached, the material is stretched and pulled tight.
The back seat is a little different. It has some of these, as well as the border of the cover has about 1mm of plastic. The hooks them go through that, and tie down. So the material does not rip..
- CHR15
these look good how much r they gonna cast and whats the time frame roughly???
- rock_it
Trying to keep a full set under $500.. Pro Seat sell for $590, but is not as nice material.. As commented by people that have Pro Seat covers..CHR15 wrote:these look good how much r they gonna cast and whats the time frame roughly???
- rock_it
Not sure when I will get back to Indo.
Will try and find my phone card and call the guy.. May be a bit hard to explain over the phone though..
