making a faster FTO?
- MADFTO
Engines really shouldn't break unless you do something really stupid to them =P 6a12 can tolerate a lot (I've sent my cylinder pressures through the roof when my air intake sucked water into the manifold, it actually survived =P )
I'm surprised no one has tried to bolt on a turbo without changing the compression, you'd need less boost charge to get the same amount of power (fuel for that matter too)
You just wouldn't get the same amount of O2 into the system, but I thought the higher comp would of made up for that *shrugs*
What would I know, I've never rebuild an engine before =) All I know is if you start modifing the engine, expect to have your car back double the estimate time you gave it =P
I'll just keep my yap shut now =)
- fto617
- Teania
- spetz
I was asking if S/C on a 6A12 MIVEC would be bad
Because of the high redline, and the supercharger usually isn't that great for high revving engines, because you would get peak power too low in the revrange
And I've driven FTO's, they seemed to have quite a lot of low end power... considering what they are
- GPXXX
and Greddy wouldn't have any gaskets for the 6A12 either...WILL wrote:Errrr
C-west never made a front bar or bodykit for the FTO
HKS never made camshafts or valves for the FTO
on another note, lowering the compression ratio may allow you run higher boost, but bear in mind that it will also make the car feel a little more sluggish to drive...
- GPXXX
you may call it what you want, just don't fool yourself into thinking it's a genuine C-West bumper specifically made for the FTO... as you know HK is notoriously known for selling cheap imitation/modified copies of branded kits... whatever it is that you've got your hands on, we'd be interested to see the pics!
- fto617
Just out of curiousity.....How much does it cost to buy a set of HKS CAMS ( if ever they make them ).....please give details of the contact where to get it from?....much appreciated!!fto617 wrote:mannnnnnnnnn
i dunno if i should get supercharger or not ! interested though
can anyone give me some ideas?
atm on my list dat i purchase for fto from hk is
hks catback system
hks powerflow
HKS camshafts
greddy gasket
HKSvalves
gettin those things from unique once i get the engine mods done
- FTO338
Hey fto617, you got the address for the place where you got your stuff from? I'm going back to Hong Kong soon, & i've got 2wks to kill.
