New rubber piping
eddiii
Post by eddiii »
ok thanks aza, guess i shall go check it out in person :) should be gettin them on sat :) cant wait ^^
if you can get them to do a test fit with the rim or even better with rubber on to see if it is the right offset for the car and dosn't rub on anything.
eddiii
Post by eddiii »
when my friend told me the price for it, he said somethin like that i have to take the front guard off or somethin -_-
Well if you have to take out guards to fit rims on then look for another set.
bushido
Post by bushido »
eddii the rim in that pic would be a wider rim than a 7.5 or 8. in order to get that much dish you would need a wide rim, say at least a 9 inch with a tough (read low) offset. That rim looks like the 19 x 9.5 with an offset of +25-28. We all know something like that wont fit with some serious guard and fender work.
eddiii
Post by eddiii »
but u think the 18x8 would fit a fto?
The 18s will fit as that's what Ben runs and I use the 17x8
you just need to get the right offset and maybe spacers.
eddiii
Post by eddiii »
im checking the "tyre bible" whats the offset lol or someone can explain to me before i found it :)
For somthing like the rims you are after I think (not 100%) you would be looking around the +38 - +40 area. But don't quote me on it it's just a ruff gess.
eddiii
Post by eddiii »
oo thanks aza, ill keep that in note, another question, how can i check what offset on my current wheels?
eddiii
Post by eddiii »
the tyres i have currently on the 18s is 225/40R18 92H
It should be stamped into the back of the rims.
eddiii
Post by eddiii »
ok i shall have a look later tonight, thanks once again aza
J
Post by J »
dish - the amount of dish depends on offset. the lower your offset the bigger dish you will have. a wider rim (eg. 8/9inch wide) will also have an effect on dish.
offset -18x8 rims with the usual +35/34/37 bob jane tmart offset can allow 3-5cm of dish from when i did some calling around a while ago, depending on spoke design.
offset should be stamped on the back of the rim. if not its on a sticker with the size and width of the rim.
you may have to remove the plastic guards behind the wheel arches if your car is preety low
arctan
Post by arctan »
anyone know if 8in wide with +30 offset will fit?
arctan wrote:anyone know if 8in wide with +30 offset will fit?
Yeah but you'll need a spacer.
arctan
Post by arctan »
so how about +38? will that require a spacer still?
I will take one of my rims off on the weekend and let you know what offset they are as I have 17 x 8s
