Brake upgrade
They do make me want to rub one out
Its not about having six pistons thou, its about having a 1200kg car and 356mm rotors - hence the lack of heat. There's not enough stopping momentum.
A V8 supercar fully loaded with driver is 1480kg and they only run 375mm rotors
A Porsche 911 turbo fully loaded is 1600kg and it only runs 356mm rotors
A VE SS Commodore has a curb weight of 1690kg at run a 320mm rotors
An EVO 8 has a curb weight of 1450kg and has 320mm rotors
A CE Lancer has a curb weight of 1320kg and has a 256mm rotos
See where Im going with this?
- FtoSam
well my car with everything in it (100kg of sound system + extra 20kg for turbo setups etc + 70kg for me) is about 1380kg... (standard dry is 1180kg)
And with hopefully more power than all of those (bar the v8 Supercar)
dont forget that there are readily available brake upgrades for all of those...
So its not THAT far off.... And as i said... if i do mountain runs, i drive at least half an hour to get there.. and with the power i should be putting out, i'll be working the brakes pretty hard as they warm up..
Some relatively soft pads should do the trick.. and just replace them a little more often...
i think by now its pretty obvious i want these for the looks... hehehe
- FtoSam
I WANT I WANT I WANT I WANT I WANT I WANT I WANT
- FtoSam
- FtoSam
They are GPX yes??? How much wear left on the pads and is it for all four or just two front?? includes discs yes?FtoSam wrote:righto...
they fit... i now own them... pick em up on wednesday...
should be fitted by the weekend....
simon, how much for my old ones?
- FtoSam
it should just be a staright fit... yes?
Ill check my finances tomorrow and get back to you but pretty keen
- FtoSam
I'd assume it would be...I8A4RE wrote:it should just be a staright fit... yes?
just let me know...
also, im thinking of upgrading the master cylinder and getting all braided lines while im at it.... opinions?
- aza013
- NSW Coordinator
well if you are upgrading then it would be a good idea to do the master cylinder and lines as well, that way you know that they are going to work the way they should.FtoSam wrote:I'd assume it would be...I8A4RE wrote:it should just be a staright fit... yes?
just let me know...
AGREEDaza013 wrote:well if you are upgrading then it would be a good idea to do the master cylinder and lines as well, that way you know that they are going to work the way they should.FtoSam wrote:I'd assume it would be...I8A4RE wrote:it should just be a staright fit... yes?
just let me know...
- FtoSam
