PHIL069 wrote:Just waiting for an official letter of offer, but it is looking like 90% yes at the moment.
I have updated in my SA thread.
BJK's '95 GPX
- kiz
- SA Coordinator
Re: BJK's '95 GPX
1998 Mitsubishi FTO GPVR AERO
- ObsidianRadio
Re: BJK's '95 GPX
kiz wrote:PHIL069 wrote:Just waiting for an official letter of offer, but it is looking like 90% yes at the moment.
I have updated in my SA thread.![]()
- bjk
- Totes
Re: BJK's '95 GPX
Okay, now I've almost definitely lost oil.
Is using it usually accompanied by a sort of burning smell? Think it was during my last hills run. The oil goes up to about mid-way between the notches on the stick.
Re: BJK's '95 GPX
How many kms has the motor done? The older they get, the more they burn. Especially during a good flogging.
- bjk
- Totes
Re: BJK's '95 GPX
187xxx now. Is this going to be something it just does?
Re: BJK's '95 GPX
Yep. The rings get worn, the valve seals wear, it happens. While mine is a bit different being boosted, I still go through at least 2 litres between 5,000k services.
Re: BJK's '95 GPX
Mine looses oil from sump scrapage lol
- bjk
- Totes
Re: BJK's '95 GPX
Are they things that I can replace? Gonna be saving up for the 200k service.Bennoz wrote:Yep. The rings get worn, the valve seals wear, it happens. While mine is a bit different being boosted, I still go through at least 2 litres between 5,000k services.
Re: BJK's '95 GPX
Yeah, you can replace them. While rebuilding the engine.
- bjk
- Totes
Re: BJK's '95 GPX
I thought that might be the case.Vectose wrote:Yeah, you can replace them. While rebuilding the engine.
Is it more viable to maintain/rebuild an older engine or swap a newer one in? There's probably a thread somewhere for this..
Re: BJK's '95 GPX
Mine burns a bit of oil when I gun it as you can see in my dyno vid.....but I never have to top it up between services and I gun it often.
Are you sure you don't have a leak out of the rear bank rocker cover gasket and the oil is burning off on the exhaust/exhaust manifold, causing a burning smell?
Re: BJK's '95 GPX
I don't notice a drop in oil level between changes either.
- bjk
- Totes
Re: BJK's '95 GPX
I'm going to check the level again tomorrow morning. I'd have no idea if I have a leak or not... should I put a piece of cardboard under the car? at the moment it sits over grassy stuff inbetween the driveway.
- kiz
- SA Coordinator
Re: BJK's '95 GPX
Yea neither, although I am starting to drip transmission oil...Vectose wrote:I don't notice a drop in oil level between changes either.
- bjk
- Totes
Re: BJK's '95 GPX
Holy f*ck. When I got a quote for comprehensive through Just Car insurance for just over $1500 (paying monthly 'cause I can't afford the whole lot, it's just under $1300 when paying for a year in full), I thought it was a little expensive, and was part of the reason I didn't go with it last time my insurance expired.
Until I called other insurers!
SGIC had the lowest excess at $450 standard and $400 age, but with a premium of +$2700.
Then I called the RAA, $400 standard, $750 age, $500 import, $500 high performance, $4681 premium.
Allianz won't even insure imports.
No wonder they say "Lucky you're with AAMI" (As Just Car is underwritten by them).
Re: BJK's '95 GPX
Re: BJK's '95 GPX
It would probably be cheaper if you get a engine with low km's put in. But even with that one you don't know it's history or if it will have any problems.
With a reconditioned one you will know what has been done and the state of the engine.
- bjk
- Totes
Re: BJK's '95 GPX
I guess I'll see how the engine is running by the time it hits 200k, and whether I'll have money to spare then (I should).
- bjk
- Totes
Re: BJK's '95 GPX
I think some guy in a Ford Falcon wagon gave me the finger as I was leaving for work. NFI why.
U mad bro?
U mad bro?
- bjk
- Totes
Re: BJK's '95 GPX
Had someone reverse into me. WHILE I WAS IN THE CAR. Some (likely old and senile) driver in a probably European hatch. Was just a bump, but they drove right off. Would've posted in the Rant Thread, but yeah.
