Plasma vs LCD
gus
Plasma vs LCD
Post by gus »
I just got my tax return and i'm going to put that money to good use, buying a bigscreen tv.
Anyone know what is better? i always thought that plasma screens are a better quality tv but seeing that a 42" plasma screen costs about the same as a 32" LCD im now not so sure.
Any thoughts?
FTO338
Post by FTO338 »
Plasma have better pictures & viewing angle.
LCD have a much longer life span, you might face a dead pixel problem down the track.
So that depends on what you want in a TV, life span or quality.
SilentBob
Post by SilentBob »
easiest rule of thumb
less than 40"...buy lcd
bigger than 40"...buy plasma
rare exceptions involve really bright rooms(plasma reflect more so lcd better) and for things like pc based still-ish images..
but plasma will give you better blacks/colours,viewing angle,and TECHNICALLY better useable life(i dont count replacing an lcd's backlight in this technicallity, you try replacing a tv's part in 5-10yrs...youll just end up buying a new tv in most cases)
Dr_Jones
Post by Dr_Jones »
Burn in is still a factor with Plasmas too so if you plan to game on it perhaps and LCD is the way to go. What about the projector route?
mrx
Post by mrx »
Went through this last weekend - bought a 42" plasma and it is amazing. But seriously, either way you will be happy.
Decidin factor though - for less or same $$, you can get a bigger set with plasma!!
But, if you are going to run your PC into it, then seriously look at LCD.
But really, it's like choosing between Angelina Jolie and Jessica Simpson - pro's and cons either way, but you wouldn't say no to either. :twisted:
Dr_Jones
Post by Dr_Jones »
I think if the only use is TV viewing and that alone then plasma wins hands down. Anything else LCD for me.
barfy
Post by barfy »
go the acer 81cm LCD get it for about $1900 has DVI and VGA imputs so u can use it as a computer screen too
gus
Post by gus »
havin a chat to a sales person today, they reckon the panasonic's need to have the same image on them for 3 days before burn in occurs. Sounds like bull to me. If you channel flick after a while does this stop the burn in occurring? I'm definitely keen for a 108cm rather than an 81cm. But i am worried about my xbox and ps2 being hooked up. Also during the Ashes the channel 9 symbol may get burned in
I really cannot decide lol. mmmmmmm 42 inches.
Dr_Jones
Post by Dr_Jones »
You'll find that the station logos actually move around slightly to avoid the problem. We have some plasmas at work displaying data and they were fried in no time. Once the damage is done it's there for good. 3 days would be a strech I think, I wouldn't feel comfortable with 3 hours.
mrx
Post by mrx »
They are getting a lot better though. With a new, "brand name" plasma, they will last a lot better. But it is best to be careful within the furst 100 hours of usage apparently.
3 days would not be good - but you should be safe for quite a few hours really. Probably 10 hours or so and you will be fine. But if you are worried, all you would have to do is flick the screen off for a bit and then back on again.
Depends what you are going to do with it, and what you watch a lot of, and what your budget is. If money was no object for the TV (like $8000+) then there are some awesome 50 inch plus LCD's out there that are next gen screens and look amazing. But personally I like the picture of plasma more, less flashy, but more realistic with more overall depth.
Up to you - just go and look at a few, and see which picture you like the most, what size you want, and what your budget will be.
As I said, both great, both different, neither will disappoint.
