Servicing your FTO
fto_gurl
Servicing your FTO
Post by fto_gurl »
Hi Guys,
Can anyone tell me how to go about servicing my FTO. Like what oil to put in and what sort of stuff needs to be changed. I don't wanna take it to the mechanics cause I don't trust the ones arouond here and if I can look after it myself I would much rather do that. So if anyone can give me some tips on how to do this can you please let me know.
Cheers.
scarecrow
Post by scarecrow »
Minor or major service? Has the 100,000km one been done yet (timing belts, etc.)??
fto_gurl
Post by fto_gurl »
yes, well I know that the timing belt has been changed and I had it serviced about 10000kms ago...
HiRAEdd
Post by HiRAEdd »
I take mine to Ricks down the Gold Coast. He's the only specialist FTO servicer in Queensland AFAIK.
scarecrow
Post by scarecrow »
Oil filter + oil, fuel filter and air filter as far as i know. Someone could elborate though.
All the known mechanical guides written by owners can be found at this amazing resource :)
http://www.completefto.com.au/FTO_showcontent.asp?hid=104
Check it out!
From what i've seen though there's only a guide on air filer and oil...
ph3var
Post by ph3var »
If it hasnt been done for a while I would change your front bank of sparkies too. (Unless you got Platinums all round).
Also flush coolant and just do a quick check of other fluids.
Custom purple 1995 GPX manual
Jase
Post by Jase »
Oil and filter every 5k. As for the rest get a service manual for the intervals on the fluids etc. It's not hard to do. The only thing i'd recommend would be putting it up on a hoist every now and then to check cv boots etc.
If you can get a service report, maybe an old one lying around or from a friend or family member, copy it. That will help with all the little things you might normally overlook.
