Temp Gauge Issues...
- ObsidianRadio
So I've had this issue for a while and I've taken a few steps to fix it...
My gauge has a habit of sitting at the 1/2 to 3/4 mark, and when I go uphill or sit at a higher speed for a couple of minutes, it maxes out... Goes back down when I reduce RPM, reduce speed or switch my heater on...
This has been going on since I've owned the car. I've not actually had an overheating issue (no steam, leaks etc). I have replaced the thermostat and the radiator and it's STILL doing it... Is there a sensor or something to blame in this case?
Re: Temp Gauge Issues...
Are fans switching on?
I had similar issue and was fixed when I replaced gauge side temp sensor. Replace that and the ECU side.
Related side note: don't ever drive a car with a temp gauge that is reading high or not working unless you don't care about it![Confused :?](./images/smilies/icon_confused.gif)
Coolant temp sensor (gauge)
- Shhtuart
The actual dash sensor and the coolant temp sensor are separate parts.Sahin wrote:Coolant temp sensor (gauge)
These ones I have don't actually have anything to do with the reading on the cluster.
http://ftoaustralia.com/v3/viewtopic.php?f=2&t=28252
Saying that, If you want one anyway shoot me a PM lol.
- vipfto
Yeah all his fans etc are working. Im leaning towards temp sensor or faulty gauge as when I test drove other day it would climb to 3/4 fans would kick in im also gonna swap out any thermo just to be sure
- Shhtuart
I can drop it in the mail today if you want. $17 for a genuine part you can't go wrong. Amayama wants $30 for them. Mitsi aus wants $47.
- ObsidianRadio
I get paid on Friday man, I'll keep you posted! Thanks so much!Shhtuart wrote:I can drop it in the mail today if you want. $17 for a genuine part you can't go wrong. Amayama wants $30 for them. Mitsi aus wants $47.
![Very Happy :D](./images/smilies/icon_biggrin.gif)
- rock_it
Pun intended...ObsidianRadio wrote:I get paid on Friday man, I'll keep you posted! Thanks so much!Shhtuart wrote:I can drop it in the mail today if you want. $17 for a genuine part you can't go wrong. Amayama wants $30 for them. Mitsi aus wants $47.
Same issue as smurfy. Gauge side temp sensor 100% sure.
That was never confirmed, rather 'sold' lolDaniel2019 wrote:Same issue as smurfy. Gauge side temp sensor 100% sure.
It was confirmed...
- SchumieFan
