Gearbox oil leal
Gearbox oil leal
Noticed my gearbox is leaking oil at both axles. How to fix?
- fraz91
- Hair-do
Re: Gearbox oil leal
Degrease it first and confirm it's the CV-input shaft seals. If so, then you'll need to remove the CV's and replace the inner seals. They're cheap from memory, but a pain in the ass to get the inner CV cups out.ftonoob wrote:Noticed my gearbox is leaking oil at both axles. How to fix?
Pop the shafts & replace the seals.ftonoob wrote:Noticed my gearbox is leaking oil at both axles. How to fix?
http://www.amayama.com/search/?q=MD755526
You could probably source the seals locally, there's nothing special about them, they're a standard type size seal. Any bearing shop can match up.
Are these just a pry and replace?
Do I have to replace axles also?
Re: Gearbox oil leak
Problem solved new seals installed. Getting axles out was a pain and honestly wasn't expecting so oil to leak out.
