Dodgy Heater
Dodgy Heater
Hey, my climate control, even when set to 32 degrees, only seems to be blowing air that is very mildly above room temperature about half the time.. It also takes a long time (sometimes up to 15 minutes) to warm up when it actually does blow warm air.
Apparently a good place to start is the thermostat? Anyone know what it may be?
Cheers.
Cheers.
Re: Dodgy Heater
Is your engine running at normal operating temp?
Blocked heater core or blocked heater hoses.
Have fun
Have fun
Re: Dodgy Heater
I have a heater core spare, not sure if it is any good but id be happy to donate it less postage to test?
Re: Dodgy Heater
He would probably want to be 100% sure the replacement heater core works before ripping out most of the dash
Re: Dodgy Heater
Engine is running fine
f**k.
f**k.
Re: Dodgy Heater
Daniel2019 wrote:Engine is running fine![]()
f**k.
Check your hoses, hose connections and the pipes at both end of the hoses for blockages first
Then go for the heater core
With my new heater core my heater gets hot as soon as the engine temp needle moves, about 3 - 4 mins in this cold weather.
Re: Dodgy Heater
I think im just going to deal with freezing and fix it when I get stuck into this new shell in a couple months.. it is summer soon, after all.
Re: Dodgy Heater
Mine is warm within 30 seconds and hot within two minutes.
Re: Dodgy Heater
I don't turn mine on for a while to allow the engine to warm up and so I don't get the cold air blowing through at startup. So mine probably would be warm sooner too
Re: Dodgy Heater
I hardly ever even use my heater though, only when it's really cold out (below 10 degrees).
I love the cold.
I love the cold.
Re: Dodgy Heater
I didn't use my heater for 3 years
Re: Dodgy Heater
I wonder why
Re: Dodgy Heater
I live in NZ, so the heater is 100% necessary
The reason I've bought an alarm with a remote start
I just need to find some way of stopping the ice on the windscreen
- payaya
Re: Dodgy Heater
Hose it off mate!Technikhaus wrote:I live in NZ, so the heater is 100% necessary![]()
The reason I've bought an alarm with a remote start![]()
Re: Dodgy Heater
Its easy to check without removing dash. All you need to do is unattach the hoses coming out of the heater core on the engine side (both of them). Jam a garden hose in one of them and turn it on. If you dont get a decent amount of water coming out the other, its blocked.
Re: Dodgy Heater
Definitely heater core.
Had the same issue in the RVR.
Cooling system was completely blocked and corroded the core out.
Enjoy.
Enjoy.
