Car died without warning?
- FTO-BOY
Hi guys! So after work I went to the shops to buy my gf a valentine gift and when I got back in the car my car didn't start... It was running fine. It crank for about a second then just died.. It's not battery nor fuse. I've smacked the starter motor a million times... Yes there's oil. And yes the car was in park and not in gear (auto)
Btw it's a 1994 mivec GPX TIPTRONIC.
- FTO-BOY
Stock as a rock
- vipfto
Re: Car died without warning?
is it still getting any electrical power with key in acc or on position
- nikhan
Lolz is your gear in Drive mode?? Else lights, radio and all working?? If not then my bet is the alternator. If it working then it might be the starter motor.
- FTO-BOY
Yeah everything is normal just prior to "on" on the ignition switch. All works except for the starter...
Do you get a click(ing) from the starter?
My initial call is sh*tty battery connections or bad earth.
- FTO-BOY
No clicking and I've disconnected and reconnected the terminals as I thought that could also be it. They look clean too. If its bad earth then nothing should work in the car right?
- vipfto
- FTO-BOY
thats 3 starter motor in 3 years
Stop starting your car then
Just roll everywhere
- FTO-BOY
Hey sahin got a spare starter from your second engine?
lol, I've got a spare here mate. $50 & its yours.
- Shhtuart
Mine used to not start in park, I just put it in neutral and it cranked.
Yeah I will have one but I think Ben is closer to you
- Supplanter
Does your car have an oil leak? One of the common leaks end up dripping on the starter motor and shortening its life.FTO-BOY wrote:thats 3 starter motor in 3 years
Or buying dodgy second hand ones from shady c*nts like me
Lolercoaster
- FTO-BOY
yeah i do infact have a leak.. all over really haha engine have done 260xxxkm
wasn't there a DIY post re: reconditioning starter motor?
*goes and check DIY section*
- payaya
Make the starter solenoid is getting power first before replacing imo.
