Moderators: IMC , Club Staff
Nevs220
Posts: 13 jedwabna poszewka promocja
Post
by Nevs220 » Mon Dec 19, 2011 6:22 pm
Bought a gpx a couple of weeks ago and recently discovered that it wont rev past 6500, does anyone know why it would be doing this, is it just a problem with the limiter or would it be something else
Cheers
Rob Furniss
Posts: 1394 Joined: Wed Jan 19, 2011 11:32 pm
Post
by Rob Furniss » Mon Dec 19, 2011 6:38 pm
Could be you're not letting it warm up or it's in safe mode for some other reason like the alternator cable isn't connected properly (the data one), reach down the back left of the engine and push on the connector - hopefully you will hear a click.
Would imagine a faulty temp sender would also cause this as it may think it's not warmed up.
Posts: 6422 Joined: Tue Oct 22, 2002 5:00 pm
Post
by Supplanter » Mon Dec 19, 2011 7:08 pm
Not letting it warm up is the most common cause for that, give it at least 10 minutes.
Nevs220
Posts: 13 Joined: Fri Dec 16, 2011 3:33 pm
Post
by Nevs220 » Mon Dec 19, 2011 9:48 pm
I dont think thats the problem cause its always been warm when driving it.
Rob Furniss
Post
by Rob Furniss » Mon Dec 19, 2011 10:06 pm
Try the alternator mate.
Posts: 3995 Joined: Wed Jan 05, 2011 11:50 am
Post
by Taz » Mon Dec 19, 2011 11:27 pm
Have you engaged your flux capacitor yet? That should be the first thing to try before anything else as its usually the problem and the easiest to fix.
Posts: 23676 Joined: Fri Jan 21, 2005 6:00 pm
Post
by Bennoz » Tue Dec 20, 2011 8:38 am
Check oil level too.
Nevs220
Post
by Nevs220 » Tue Dec 20, 2011 12:18 pm
I've already been back to the future so it cant be that.
martin92
Posts: 10 Joined: Sun Jan 30, 2011 4:11 pm
Post
by martin92 » Tue Dec 20, 2011 1:23 pm
the timing might be out. turn the engine over and get dead centre and check to see if it lines up with the timing marks.
Nevs220
Post
by Nevs220 » Tue Dec 20, 2011 1:30 pm
I just came back from the mechanic, he is going to scan it tomorrow morning if there is no error codes then he is going to check the timing belt.
He thinks its something mechanical because there is no engine light.
Posts: 6793 Joined: Tue Oct 13, 2009 5:00 pm
Post
by silverGPX » Tue Dec 20, 2011 4:43 pm
Dude we arent retarded, if it wont hit mivec, either your oil is too low, your alternators fucked or your have a faulty engine temp sensor.
Posts: 3670 Joined: Sat Sep 06, 2003 5:00 pm
Post
by payaya » Wed Dec 21, 2011 7:21 pm
martin92 wrote: the timing might be out. turn the engine over and get dead centre and check to see if it lines up with the timing marks.
Man if your timing is even off by one tooth on one cam your car runs like sh*t and your engine vibrates like crazy during idle.
Nevs220
Post
by Nevs220 » Fri Dec 23, 2011 4:36 pm
Got the car scanned and got an error code from the knock sensor.
Posts: 2730 Joined: Tue Jul 21, 2009 5:00 pm
Post
by Shane001 » Fri Dec 23, 2011 7:21 pm
That's unusual but I'd expect that could cause your problems.
Check connections first if not just get another second hand unit. Unusual for these to fail.
