lawsochap wrote:Check the tires, if there isn't enough pressure on start, the tire pressure sensor won't allow the car to start, and put the car is 'limp home mode' where only an authorised mitsubishi dealer can repair the problem, which involves sending the ar to japan, because the car is a grey import, no mitsubishi dealer in australia can fix the problem.
