need help with parts..
hey guys my fto has already been in workshop for 2 months and i need your help... looking for cylinder valves and gasket kit for gpx.. ordered set from japan but they got me the wrong one and that took me 2 weeks.. and now i'm up to a dude in singapore he said he's got something like that but he wasn't so sure if it's for GPX.. guys... where else can i possibly look for those parts...and i want something quick..because.. i miss my FTO!!..
- SchumieFan
Re: need help with parts..
from memory i had a valve replaced off a 4 cyl mitsi, not sure which one though, and a valve guide from a b6 mazda
gpx gasket kit shouldnt be too hard to get, someone else should be able to tell you where to go for that, i got mine from Mitsi direct
Valves are generic. If your workshop has trouble finding them, change workshop.
- Sweep
I got my Gasket set from camskill, and I too had trouble locating the valves, I had a couple fabricated for $80.00 each.
thanks guys for your help... hey Sweep, i didnt know we can fabricate the valve!! where exactly can i get that one done?
- Sweep
Theirs a engineering place up where I live.
You would have to take in one of your good valves into somewhere similar and ask if they can make another one, if you get really stuck I could probably get another made up for you.
But chances are you should be able to sort somthing out.
- Shane001
I'd be sourcing genuine valves or quality aftermarket units, this is not something you want to have made up by your local toolshop. In my experience, and Ben will probably back me up on this, most local toolshops haven't got a f**king clue what they're doing lol!
They are the same as E54A & E64A Galant. Shouldn't be too hard to find.
http://www.camskill.co.uk/products.php? ... b0s9p64144
http://www.camskill.co.uk/products.php? ... b0s9p64143
Yeah tool makers are a bit hit & miss with those sorts of things.
Fortunately a mate I went to school with is a qualified tool maker & he's made some up for me in the past (for my Mini) & its quite the science. Gotta use the right grade of steel to start with (and its a substantial list to pick from!) based on what material the head is made from & how the valve seats are done, then there's all the heat treating processes that are applied to the valve after its been cut from the block of source material. Plus once thats all done, just hope they got the measurements right! 1/2 a mil too long can end in disaster!
I can probably get genuine ones, but it would take from 2-3 weeks (japan currently on a week long holliday). I have got 3 engines in the shed if you are willing to go 2nd hand (blown head gaskets). The valves should be fine though.
- Shane001
Plus it will cost a shitload for them to make up just one valve, assuming they do do it rightBennoz wrote:Yeah tool makers are a bit hit & miss with those sorts of things.
Just click on the links I provided above and you'll have em in a week
Alright thanks for the suggestion guys, really helpful.
Dstocks: I called japan mitsubishi the other day and told them my situation.. they didn't turn me down but instead of that they replied me "usually the parts take 3-4 weeks to deliver but it's gonna be 6-8 weeks or longer since natural disaster hit us"... speechless man..
shane001: thanks for the links, i will probably e-mail camskill about that!!
dstocks, would u like to sell me the parts?
Have managed to get the lower head off one that contains 6 inlet and 6 outlet valves. If you want new ones, I can order them, but Japan is on hollidays until the 4th May, so wont get an answer before then re price and how long it will take. Have sent you a PM as well
