Cam Gear and Sensor Talk
Re: Cam Gear and Sensor Talk
Ok I will dig it out at get a pic of it for you :D
Edit:
OK the pics are up :D
and yes the spiders have had there way with them :lol:
I should give this a bump as I did a edit yesterday to add the pics and you may not have seen it :lol:
Ok, so clearly the plate can only go the one way on either gear - so long as its the Mivec plate thats being used. The tab vs the cam locating dowel on the gears are in the same spot.
So if that can't be fucked up, the only thing left that can be fucked up - is the timing belt. My guess, they got the belt out by at least 1 tooth.
Get 'em to redo it, this time making absolutely sure, all the verniers are centred at 0 degrees before they put the timing belt on.
The plates are diferent :?
Also the gears are a lot biger than the ones I have posted up :?
Yeah we know the plates are different. The GR ones are smaller, hence the gears look different in size.
Ok now I am :scratch: is it a gr engine or mivec :?
I really don't want to go back over the other thread :lol:
bent a valve putting the cam belt on out by 2 teeth.... easy to do, but easy to realise youve done as well...
get em to re-do it!
Valandis91
Post by Valandis91 »
Bennoz wrote:Ok, so clearly the plate can only go the one way on either gear - so long as its the Mivec plate thats being used. The tab vs the cam locating dowel on the gears are in the same spot.
Oh yeah haha dumb idiots.
i love you ben!
they're going to love the news they get to put them on for free muahahaha!
so they would only have to drill into the mivec plate which they mustve done since there is a pic with it on but since they fucked the cam belt thats why it wouldnt run!
THANK YOU!
and aza for supplying the winning pics!
Did you want me to send you the cam gear or is the pic fine for What you need?
Valandis91
If you dont need it it would help i suppose?
would it be worth shipping down?
I don't know mate, I think Ben could answer that better than me.
But if needed I am happy to send it down as a eg for them to work off.
Valandis91
well if you ship it down to me ill send it back once we're done to it?
i guess it make it easier and confirm they stuffed up!
Ok pm me your address and I will send it down to you.
Valandis91
thank you aza for the cam wheel i got very excited when i got mail today!
theyre exactly the same...
which means!
i get to go in on thursday and be like you guys fail not put them on properly and dont stuff up the timing belt this time.
sigh such annoying things be interesting to see what they say, or the look on their faces when they realise they stuffed up another thing and have to fix it,
sh*t it maid it this time :lol:
Just remember, they must be set at zero degrees before putting them on ;)
Valandis91
so went in today and spoke to the owner not the guy that did the work he looked at them at said he couldnt see how they wouldnt go on and fix.
then the tool bag that did the work came in and was like he couldnt get the notch in the plate to line up on the othe cam wheel, sigh, now theyre also ssaying to make sure the dowel is correctly placed,
they didnt seem keen to do it again as you would presume cos it is a lot of work they have to do.
so meh.
Valandis91
Well all i can say is FML...
For those of you who know whats going on this picture will explain everything.
Now for a more detailed explanation as you can the sensor plate is out by one tooth. hence why it would make sense the car wasnt running properly. FML.
If the plate is out of place it also means the dowel for the camshaft is out of place. FML.
now my mechanics dont know this. as i told them everything you guys said on here and the owners are swaying my way over the retard mechanic that did the work including my seals so what im hoping is going to happen is they are getting sent back to envy dyno and made properly without my mechanics knowledge and then ill go back to them and say i measured them and everything and you stuffed up the timing belt or something.
just something so they can put them on. ive also got another oil leak. just great looks like they'll be pulling apart my engine again anyways. just seriously FML and i have the worst luck ever.
Oil leaks are a bitch, as soon as you find one and fix it the oil will find another week spot and push out there :?
Valandis91
aza013 wrote:Oil leaks are a bitch, as soon as you find one and fix it the oil will find another week spot and push out there :?
theyre all brand new seals so its just the muppets putting them in that fail.
sigh
