bduffman
Post by bduffman »
changed spark plugs and camskill ignition leads now my cars idol is way high 1.5k u should have seen the old plugs though massive gap had burnt the tip so far down and they had normal plugs not in the back sat machanic strip engine down for new tappets cam belts timing belt water pump oil change should be a new car by the end of the week
Tippin
Post by Tippin »
bduffman wrote: you should have seen the old plugs though massive gap had burnt the tip so far down and they had normal plugs not in the back sat machanic strip engine down
what? :lol:
fraz91
Hair-do
Post by fraz91 »
boost gauge is a working. Lawso gave me a hand (well... sat in the passenger seat and fell asleep :P) question, is ~25psi boost normal for a diesel with a Variable Geometry turbo? because thats what the gauge is reading... and i dunno if its faulty or accurate :P
vipfto
Post by vipfto »
Got car back today front bar and skirt look hot will get some pics up when got mesh in sits 8mm from ground :twisted: but will raise it just dont wanna risk any damage :?
vipfto wrote:Got car back today front bar and skirt look hot will get some pics up when got mesh in sits 8mm from ground :twisted: but will raise it just dont wanna risk any damage :?
8mm off the ground sh*t that is low but it would look soooo hot :twisted:
FTO_GPvR
Post by FTO_GPvR »
Yeah that is heaps low but i think he meant to say 8cm off the ground
maggsy
Post by maggsy »
well on Tuesday i started work on my new pod box housing (or whatever you want to call it). Made some templates using cardboard, then, when I realised the cardboard was too thin made some new templates.
the design is a 3 piece box consisting of a base, a back and a side wall, (lid to be made soon).
Made the base on Wednesday, side wall today and rear wall tomorrow.
Designs are similar to Dstocks but i had to make some changes because my intake tube will be entering right on a corner, which i had some dramas working around.
pics to come :D
vipfto
Post by vipfto »
nope 8mm Had to raise it up last night :cry: BTW where is best place to get mesh for front bar too?
Most auto shops have it.
zuihoujueding
Post by zuihoujueding »
reconnected led parkers as cables came loose.
changed headlight lamp. all at 1am in the morning.
Tippin
Post by Tippin »
prepped up the new spoilerless boot, all ready for spraying tomorrow :D
Well today I had the car retuned and got some more power out of it :twisted:
now running 137.2kws.
I'm slow and steady getting to the finish line of 150 :D
She sounds f*cking hot too!
Get those extractors on!
Yep I will have to do that.
It sounds good but when yours got a boot full oh sh*t I had to cover up the woody I was getting, I could not help but grin every time.
Tippin
Post by Tippin »
boot primered, will have to wait till monday to start colour and clear coats
aza013 wrote:Yep I will have to do that.
But Brent knows his sh*t hey. Guy's a genius on the dyno, especially with a Haltech. On your first run, he just looks at the graphs & says "Running heaps lean, gimmie a minute I'll sort it."
By the time I came back from the shops with those bottles of Coke, he was done & you had 137kws :lol:
Yep you are spot on there :D
it was well worth the drive out there for the day, the old saying two birds with the one stone :D
I may even go out there every time I need a retune.
I did nothinng today....... I was wakeboarding :twisted:
nicholas
Post by nicholas »
I8A4RE wrote:I did nothinng today....... I was wakeboarding :twisted:
Like.
Resident Asshole.
I miss my wakeboarding days :(
