Gear Change in Auto
Sophia
Gear Change in Auto
Post by Sophia »
Just are thought really, is it bad to change the gears (ie. drive to reverse) while the car isnt completely stopped? Sometimes I do it while the car is rolling slightly and just wondered if it was bad.... :?
Dont laugh to har if this a idiotic question :oops:
FTEvolution
Post by FTEvolution »
I did it once in a blaze of idiocy. I went from drive to reverse (I usually hit neutral from drive, but that day I for some reason depressed the button allowing reverse, got a small clunk then a tick tick tick noise til I stopped. All was fine though after that so I guess it was a fail safe.
In short, not a good idea. Drive, stop, engage reverse. Now, coasting in neutral (like rolling a little on a slope) then hitting reverse is ok. It is relevant how much speed you are carrying when you engage reverse. In general, you don't want to put an auto into reverse while it's going forward :)
Smooth and sleepy
-Nighthawk-
Post by -Nighthawk- »
I nearly put my car into reverse while driving 80kmph. Was going to change gear thought something wasn't right so I tried to push the gear up to go up a gear and it went into neutral. So putting it into reverse will only slightly damage it not come to a complete stop?
And people wonder why there are so many issues with tip boxes.
@OP, dont do it sophia unless you want expensive repairs.
Sophia
Post by Sophia »
Thank you, short and simple was the answer I was looking for :)
Drive to Neutral is fine.
But reverse should never be selected if the car is moving forward, only if at a complete stop.
Storm
Post by Storm »
I was under the impression that there is a failsafe mechanism to stop an auto box engaging if you are moving forward at any rate and stick it in reverse by accident :|
FTEvolution
Storm wrote:I was under the impression that there is a failsafe mechanism to stop an auto box engaging if you are moving forward at any rate and stick it in reverse by accident :|
There is, if you read my post you will see what I mean. But in short, don't do it... I'm sure it won't take many occurances to render the failsafe inoperable and then your box will be fucked
Smooth and sleepy
There is no failsafe when your reversing at low speed then change to drive
brad_gpx
Post by brad_gpx »
i have done this 2-3 times in my manual
forgetting there is no 6th gear just reverse
always makes i pleasant grinding noise
FTEvolution wrote:blaze of idiocy
You should be a news reader!
FTEvolution
stfu :jerry:
:P :P :P
"and in breaking news today, once again in a blaze of idiocy, nate put his car into reverse while entering a service station"
:oops:
kids, if you want to learn what *not* to do, in any way shape or form, just watch what nate does...
:cry:
Smooth and sleepy
