really newbie question
arctan
Post by arctan »
but where the heck is the antenna on the car?
I've gone around my car and can't find it
BorepYano
Post by BorepYano »
built into the rear windscreen
in the really early models it was infront of the left headlight (youd know if it was there) then it was either on the back left hand corner of the car in the gr and gpx's, or part of the window demister in the rear window of the gs and some gr models
I am pretty sure that the front aerial was to assist parking. My car is a 95 model and it came with the front one and the rear motorised one as well.
i havnt seen one since, but years ago i saw a silver 94 with a front aerial and no rear one... but it may have been in the rear window...
personally, i prefer the external rear one...
though the half and half switch is a bit of a gimmick, the only time you need it fully up is in the wop wops and then your travelling at such speed they tend to bend and then not go down properly when you turn the ignition off (or if you go under a farmers fence)
arctan
Post by arctan »
SchumieFan wrote:in the really early models it was infront of the left headlight (youd know if it was there) then it was either on the back left hand corner of the car in the gr and gpx's, or part of the window demister in the rear window of the gs and some gr models
ok thanks might have a look at the demister. trying to figure out why the radio won't work with my headunit.
My car is a GP(pre facelift GPvR)
vipfto
Post by vipfto »
yip in back window on some models was factory option....
do you have stock headunit still? you may need band expander or best to just change whole thing
arctan
Post by arctan »
vipfto wrote:yip in back window on some models was factory option....
nah an old sony deck thats about 6-7 years old
hesistant to replace it as it looks damn good and there's nothing similar to it. The only thing I'd consider replacing it with would be a touchscreen
Maybe the aerial plug fell out.
