Not sure man but if you get me the gates equivalant numbers i can get some good prices for you
Water Pump is located under the timing covers. It is run off the timing belt.
Gates are just as good if not better than OEM. We use gates here on all our machines and if one failed it would cost us tens of thousands of dollars. They run everyday all day..... So yeah very reliable.
