Hey all is there a test you can do to see if your oxygen sensor is 100%?
thanks
Oxygen Sensor
- payaya
- smorison
- The Godfather
Re: Oxygen Sensor
pretty sure it spits out error codes, check the FTO Manuals (techincal ones)payaya wrote:Hey all is there a test you can do to see if your oxygen sensor is 100%?
thanks
- smorison
- The Godfather
when you ground pin 1 for the O2 sensor and it flashes error code 11, what does that tell you? i was looking at the disgnosis box thing the other day and i couldnt make any sense of it....if it flashes when you ground a particular pin, what does that mean?
i was looking into this too cos i think my mechanic took out my O2 sensor when he installed my extractors and flex pipe....and i dont think he welded it back into the new flex pipe.....so im running an open loop...running rich and getting bad economy
- smorison
- The Godfather
Chiangstar wrote:when you ground pin 1 for the O2 sensor and it flashes error code 11, what does that tell you? i was looking at the disgnosis box thing the other day and i couldnt make any sense of it....if it flashes when you ground a particular pin, what does that mean?
welded it???? sh*t i hope not cause its supposed to SCREW IN!
i would imagine that the O2 sensor has been cooked if he WELDED it in, and if he did i wouldn't be going there.
