speedo has gone on holiday
Sugar
Post by Sugar »
hi guys
my speedo has stopped working
the rest of the gauges are fine
its also not adding km/s i supose they go hand in hand
any ideas?
just stay behind another car and you will be ok with speed :D
as for the K's not working that is a + for you :twisted:
harry90
Post by harry90 »
lol....
it could just be something gone loose ? :?
Grue
Post by Grue »
1st and easiest one to check is that the dial cluster is slotted into it's connectors ok. take her out and put her back in.
Sugar
Post by Sugar »
yes that was the first thing i tryed.
I will probably have a gauge lying around somewhere if you get desperate mate
    I think it would be more like the connection at the gearbox but im not family with the manual g/box
    Sugar
    Post by Sugar »
    its a tip mate :)
    ill have a look and make sure they are all there tomorrow
    Sugar
    Post by Sugar »
    what exactly am i looking for? on the tip box
    Sugar
    Post by Sugar »
    well everything looks to be in order on the box.
    just fiddled with stuff lol!
    upon further inspection
    in the drivers wheel arch.. i took out the plastic liner as it was rubbing badly. i looked up and there are a few wires that have had the plastic coating stripped and bare wires are showing..
    could be a reason?
    i doubt it, i dont think the wires travel through the wheel arch but i could be wrong, mate if i didnt have so much on plate at the moment i would try and have a look sorry. The only thing i can suggest is check out the wiring manual and try and see what the wire colours are.
    Case of piss! :D
    oh ben, you whore :lol:
    Sugar
    Post by Sugar »
    Okie dokie
    checked the gearbox.. all seems to be in order
    still a bit concearned about open wires in drivers wheel arch.. so i taped them for now..
    may have to get a new cluster (hi dwayne)
    but just out of curiosity can you make the speedo needle move with the gauges off the car? connect power to any of it?
    FtoSam
    Post by FtoSam »
    put it in another FTO... voila!
    nicholas
    Post by nicholas »
    Dunno, but the tacho on both my FTOs was f*cked when I got em. Replaced a sensor and voila. Could be a sensor?
    If it were a manual, I would have said drive to my place and we could of swaped over the units to see if it worked... Not sure if a tip cluster will work on a manual ...
    But if you want to head out here and try it, let me know.... Just a short trip down the m5 ...
    Sugar
    Post by Sugar »
    thanks mr rock it will have another play with it this weekendand see how we go
    No probs ...
