ive had a play with the new air ram cone to day got the ally pipe the right lenght . i took my iduction pipe a part to use the rigrt angul bends looking at it ill ether have to cut the pipping down and use 3 90 degrees pipes or 1 90 degree and a 180 degree or 2 90's and a 20 degree kink
what do you think will be best?
thanks
martin
air ram pipe question ??
- tintin
coilovers!! gaurenteed to make boobs bounce ![Smile :)](./images/smilies/icon_smile.gif)
![Image](http://i85.photobucket.com/albums/k47/v6colt/TINTIN2.jpg)
- mr-charisma
why you using the alloy piping for an air ram? should get yourself a length of some plastic flexi hose with a decent diameter.. not only is it lighter, but its more forgiving in the bends..
anyways... 2 90's with a 20 degree kink is the lesser of three evils..
depends on your setup as to what oyu can get away with i spose..
- tintin
cheers.mr-charisma wrote:why you using the alloy piping for an air ram? should get yourself a length of some plastic flexi hose with a decent diameter.. not only is it lighter, but its more forgiving in the bends..
the reson im not using flexi pipe is cos its got ribs in so the air wont flow as much . say as silicone hosing and ally pipe
- mr-charisma
- tintin
