ive browsed quite a lot and used the search function but i need some straight answers now.
exhaust systems, ...whats that standard piping diamter? im asuming a 2.25 - 2.5 inch system would be more than enough for these small engines asuming they are atmo ?
Having a 4 speed tiptronic, does the ehaust get very droney down low if i had a cannon? does anyone have a magna flow muffler fitted ? im not sure what to fit
I read some of u have magna throttle bodys, do these bolt right on or do they need to be modified?
what are the stock diametres for MIVEC tb's? (60mm ? )
Do Fto's use the same air flow sensor as the magnas? and if so FTO's would be better off with an oval pod that most modded mtsus use rather than my cheapo paper pod i have now ?
Magna throttle bodies can be bòred out to 70mm.. (72 mm if u really push it) have any of u guys done this ?
Is it not worth my time getting head work done if i have a mivec? will it likly cause problems ?
Can the FTO ECU be reflashed? or do u need a piggy back to do so ?
there is a product for Vtechs where u can lower or raise the amount of revs when the valves open up , is something like this available for FTO's ?
i dont think modifying this engine to be an atmo beast will give me the gains i want for the right amount of $$$, i dont want turbo, plus ive heard turbo + mivec is bad news, sooooooooooooo
what supercharger kits are out there ?rpw i assume? what else? nothing extreme.
lastly, i am able to get performace parts at a pretty good price from freinds of mine, im thinknig about a simple nos kit. (for now)
how much HP is safe ? im thinking a 75 hp nozzle would do the job and not cause any damage ?
thanks for your help, sorry if its been covered before
