Hi guys,
My new car has an aftermarket but JDM-spec head unit, and the screen has stopped working.
I wanna replace it but was wondering where I can buy an adapter so it'll fit aus head-decks (i searched, couldn't find nothing).
Cheers!
Replacing JDM head unit
- nicholas
I might be misunderstanding your question, but if you wanna replace the deck, you should be able to replace it with any aus unit you like...
If it's double DIN, replace it with a double DIN deck or single DIN and use a blanking plate or pocket underneath it.
The only adaptor you might need are the brackets that bolt onto the side of the deck and then screw into the console.
You can get these from Mitsi dealerships locally, they're not overly expensive.
[img]http://img259.imageshack.us/img259/1613/sigpic2se2.jpg[/img]
- SILVERFISH
- VIC Coordinator
if you're after the headunit mounting brackets...
here's the info you need courtesy of an old Supplanter post -
mine cost me approx. $20Supplanter wrote:If you don't have the brackets, they are the same as the CE Lancer.
you can buy them from an authorised parts dealer (try your local Mitsubishi dealer)
Part Numbers: MB874343 and MB874344 (one for the right, one for the left).
- Supplanter
Go meS1LVERFISH wrote:if you're after the headunit mounting brackets...
![Very Happy :D](./images/smilies/icon_biggrin.gif)
Mine were about $36 from Chaadstone Mitsubishi... I got ripped
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
- SILVERFISH
- VIC Coordinator
...hence the reason i didn't include that part of your original postSupplanter wrote:Mine were about $36 from Chaadstone Mitsubishi... I got ripped
- nicholas
Hmm, it sounds like you guys don't know what I'm talking about... which makes me think i'm talking crap haha.
What i meant, was that when I tried to swap the head unit for a new one, the plugs at the back wouldn't fit (the power one did, but the other one didn't) and so I thought you'd need a converter
yes / no?
yes / no?
- Supplanter
- Supplanter
It comes with it's own wiring harness with a plug on the end. this plug connects to a generic plug that common cars have that connects to the speakers. With the FTO you need a converter, that's my understanding of it anyway. As I said, I just cut the plug off the head unit and soldered the wires into the FTO ones.
