gpx and gr
gpx and gr
is gpx and gr have the same idle speed motor controller? anybody know the parts no. of those stuff? thanks a lot..
- Daz_FTO
Did you skim through the parts list on this site under the FTO information section?
http://www.ftoaustralia.com/modules.php ... ries&cid=3
Re: gpx and gr
I only have one part number for that, so it may be the same for the GPX and GR. But double check:MiVEC wrote:is gpx and gr have the same idle speed motor controller? anybody know the parts no. of those stuff? thanks a lot..
MD614568
I got a print out from a download from FTOOC UK website.
Your best bet is to ring Mitsubishi with both part numbers. I'm sure they will be able to do a lookup on their database pretty quickly.
I also remembered someone on this forum having a CD with all the part numbers for the FTO. Hopefully he/she is still around and can search for it also.
PS:Northshore Mitsubishi has searched a part for me before, so I'm sure they can help. Give them a call. You don't have to buy the part from them.
