ECU
ECU
What colour is the ECU of a fto?
Hi lal,
Well, if your car is a manual then it doesn't make any difference so don't even bother about resetting your ECU.
However, if your car is a tip, then resetting will make the car re-learn how you drive your car.
So, currently the car is used to the previous owner and how that person were driving.
But by resetting the ECU, you are in fact making your car suited to you.
Therefore, at first after you reset you ECU, your car will seem a little bit funny as it is trying to figure out how you drive, but eventually it will adjust it self.
The main benefits are that it could save you more petrol, as it won't be changing gears when you least expected it, due to how the previous owner had been driving.
And a more comfortable and smooth rides for you, as it will try and drive the car the way you want to drive the car.
Hope this helps,
Cheers,
Hope this helps,
Cheers,
- smorison
- The Godfather
fto12345 wrote:Hi lal,
Cheers,
just on this couple of comments
1. the TIP box has a seperate ECU. INVECS II is not controlled by the Engine ECU
2. The TIP ECU is constantly relearning driving styles no need to reset it, just take it for a nice long drive the way you normally drive and it'll learn it.
- smorison
- The Godfather
- rxboy
