Tiptronic box parts
Tiptronic box parts
I am having trouble finding parts for my tip box. I know we share a lot of parts with Galants and Lancers, does anyone know if the box is simular to any other Mitsi models. Has anyone found parts for a tip box, particularly in Brisbane?
Thanks for the help.
Jeff
Jeff
- smorison
- The Godfather
- smorison
- The Godfather
- wildfaye
hmm...if i m not wrong...
the ftos are 2wd, the magnas are 4wd, so the gearbox is the same except that the 4wd gearbox transmits to all 4 instead of 2 wheels.
initially i tot the Evo7 GTA and Galant vr4 gearbox is able to do a direct swap, but proved otherwise due to the 2/4wheel thingy.
correct me if i m wrong.
cheers
sam
cheers
sam
- rxboy
When my 5-speed tip transmission was being reconditioned, the mechanic told me that he had to get some parts from Japan because there weren't any 5-speed tip FTOs being wrecked in Australia. I suggested using the parts from a Magna with a 5-speed INVECS-II box, but he assured me that they are not compatible. I really have no way of confirming this, but this guy is a reputable repairer of Jap import auto transmissions in Melbourne.
- Supplanter
depends on what parts you need, i would think that the magna gearbox would be a lot different due to the fact its a very different engine, producing power down low and not a high revving design like our cars, also i dont think the lancers have a 5 speed tip, well not that im aware of, your finaly option would be the galant 6a12 model, which would be possible to source parts if you had the 4 speed, but i dont think there were any 5 speeds made, unless you sourced parts from a 97 model onwards, which would be ever harder then sourcing them from an fto. So i dunno what you can do except get the exact part names in which you need to replace, and ring up mitsubishi or go to mitshubishi and make sure you speak to a mechanic there, and just tell him you need those parts, is he aware of parts which are similar on any of the other mitsubishi cars sold in aust, or even take the broken parts to see if they could match them up.
good luck anyways
good luck anyways
- rxboy
