FSE Fuel Pressure Regulators
- J1
Does anyone know the difference between the FSE Fuel Pressure Regulator and the FSE Power Boost Valve? RPW recommend the latter but I don't know what the difference is.
Anyone got the part number for the one appropriate for my GPX FTO? I'm thinking of just buying it from Autobarn cos it's cheaper than getting it sent over from WA. Problem is I don't think they know what they're talking about so I want to be able to give them the exact part number so they can just order it and minimise hassles
- elmo
regulators
The thingy they fit with the extractors is a rising rate fuel pressure regulator. I dunno if this is what you mean, is it for the same purpose?
What it does is increase the fuel flow/pressure to the injectors as you rev the car. It has a little glass gauge on it that tells you the fuel pressure at idle and you can watch it go up as you rev it. There is also a screw on top that you can adjust the idle pressure which i think in turn adjusts the reving pressure.
So thats what i got, but i cant tell you which one it is.
- MattG
- J1
I thought they were the same thing, but one costs about $90 more than the other. Apparently the cheaper one is not a "rising rate" FPR, just a standard one. One question, if it's not a rising rate FPR, what's the point of it???
Apparently the FSE PBV kit contains a Malpassi adjustable regulator, according to Online Performance Autos.
Anyone know who can install one of these in Melbourne?
Do you have a good reason for having one fitted? I have seen loads of reviews in car magazines where they do before and after power runs on standard and lightly modified cars (exhaust + filter) and they never give the results claimed by the manufacturer. They always conclude that they're a waste of money. I haven't seen anything specific for FTO though, so who knows?
Let us know how you get on.
- elmo
fuel pressure
guess the fuel pressure regulator would be adjustable and you would set it at the maximum pressure the car requires.
The beauty of the rising one is that the pressure goes up and down as it is required. This would probably mean less wear and tear on the fuel pump etc and maybe even using less fuel at idle??
- kaveman
the car has a standard fpr but it can not be adjusted
why would you fix a aftermarket fpr
a fpr keeps the presure of the fuel in the rails
so what does this mean
you cars fuel pump is alway pumping fuel around
when your car is sitting there idling the presure stays level
as soon as you put you foot down it drains fuel and sents it to the injectors
therefore there is lest presure to push the fuel into the injectors
an aftermarket fpr you can set the presure
i have mine set about 4psi higher then standard
i think it about 32psi
fpr are normal added to turbo/supercharged as they need extra fuel as you are pushing more air throught
hope this make sense
robert
robert
- elmo
FPR
erm... think mine idles at about 34 then goes up to like 50????
thought standard was 28??? Will ask RPW...
Yoo hooo that reminds me they gonna spend the whole week on my car and should be done when i get back from holidays. Be gald to get my wheels back.
- elmo
fpr
hmmm... maybe they set it wrong when it was installed, but i'm pretty sure they told me not to go above 38-40? Maybe that is why i cant notice a difference no matter how far i turned it down, cause I am running a less than stock fuel pressure.
Will test it next week.
